preface: i knew nothing about how to get inside my 1999 solara v6 manual
1.took it to jiffy lube
2. two days go by, start losing power, no check engine light, no leaking fluids, checked dipstick on warm engine said full(MISTAKE) , looked at invoice says they put in 6 quarts of the recommended type /oil filter was the right part. figured coincidence
3. next day power loss significantly reduced, look online... says fuel system issue
4. back to jiffy lube for a fuel line cleaning... no improvement
5. spend more time looking online says spark plugs/fuel filter/fuel pump
6. go to autoparts store to buy tools/parts car can barely make it with out going into 5000 rpm
7. get home change plugs no difference, change fuses/fuel pump no difference, change fuel filter MAJOR BLOCKAGE! no difference
8 spend the next two days online downloading manuals reading specs pulling hair out also figuring out how to disable anti theft system that is now active from pulling the negative terminal
10. buy multimeter/compression tester
11. check plug,fuel pump wires fine, maf sensor/throttle position sensor fine. compression test 235 across the board injectors clicking away, pull o2 sensor check for back pressure from exaust just like eric the car guy said.... no pressure.
13. starting to notice build up underneath transmission.. oil? online says worn clutch could be the cause so i test it by puting it in 3rd and letting go of the clutch ITS THE CLUTCH!!! f me must have entered "high rpm-no power" 35 times into google watched countles hours of youtube vids no result said anything about the freakin clutch dude. but that drop in power so sudden right after the oil change look online.... oily clutch... overfilling causing gasket failure... rear main seal.
14.check dipstick again on cold engine... double the full line... wtf
15.ordered atp reseal/clutch kit/jack&stands got the car on the stands. looking at the oil pan and it has a red tamper paint seal on the bolt, called jiffy lube. they say red is what their technicians use.
so they drained the oil and filled it with 6 quarts supposedly, but now the bottom of the engine is caked. and my clutch is either worn or covered in oil.
i have the clutch kit. what do i do next pls help im trying to do it myself but theres so many what ifs and i really dont want to have to pull the transmission and my head hurts from looking at that dang **********s pdf.
