Tfar - best measuring definition yet. The lesson in how tight is TOO ^&%#@&!! TIGHT is when you do your first oil change after the neanderthal moron at jiffy lube tightened the drain plug to about 900 ft. lbs.
Since I never remember to have a new one available I just completely clean the old washer, lay a small sheet of sandpaper on the bench and sand both sides to remove any scoring.
1 - 6 of 6 Posts
