1 - 9 of 9 Posts
I'm the new owner of 2017 Highlander XLE Hybrid . love everything on this car but noticed that by heavy acceleration it is asking to hold the steering wheel in the correct position. I'm not the person that races this car, but had a situation that I needed to floor it to avoid an accident. I have simulated it a couple of times and it does it every time any body else:surprise: has this experienced ?
I haven't but then I'm still in the break in mode so no hard acceleration yet.
But I have read about torque steer with the Hybrid in a review by Car and Driver from last Oct:
http://www.caranddriver.com/toyota/highlander
It also had a disconcerting torque-steer issue. Toyota engineers attributed this to calibration of the electrically assisted power-steering system in the preproduction example we drove; its anti-torque-steer logic had not yet been finalized, they said. It should be fixed before the hybrid reaches showrooms.
Guess it wasn't fixed.
Thanks for that link. I did some further testing when it occurred, I took it on a straight stretch road and floored it and noticed that it is still present (minimum) but when I repeated it on a curved road it was very noticeable. It gave the same feeling in the steering wheel when the line departure is engaged but did not make any difference when it was turned off. Shortly after I bought the vehicle I replaced new 19" rims and tires and noticed this morning after driving with new tires about 600 K's that the tire warning light came on. I checked the pressure and in all tires it was 30 PSI. I contacted the supplier and was told it should be 35 PSI. nitrogen. now with the correct pressure it seems to be way better but is still noticeable.
Huh. I enjoy that torque steer. Donno what Toyota engineers say, it's torque steer. Asymmetric driveaxles. One shorter transfers torque faster, one longer, though it has intermediate shaft, lags behind.
But, personally, I like it! Every time I floor mine - and I do! - reminds me of Jeremy Clarkson testing some sport car. HiHy has lots of torques due to electric motors involved.
Torque steer
Thanks for your comment here is a link explaining details with the effect of torque steer in details .www.aa1car.com
Under torque steer , you are correct that the diffent length of drive shafts could be one of the problems but also noticed that
That torque steer is most likely not present for car with less than appr. 200 hp. Lander over 300 hp, I, did not had this problem with my RAV 4
2016 hybrid limited that to my opinion has the same configuration as the Highlander? you mentioned that you like it , but personally I don't and I think it is fair to say that inexperienced drivers will have a hand full to correct it when it occurred especially on wet roads . Pickapooly
Yep. Lots of horses and torques. Like or not - it's actually quite a sporty vehicle.
As far as I know, overall power train layout is same for conventional and hybrid models.
If you want NO torque steer, buy Subaru. Symmetric 4WD. Dead smack on center of the vehicle. They have hybrid available.
Honestly, not that HiHy burns rubber and goes sidewise under acceleration. Attentive driver that knows it's coming, should easily control minor tail whip.
Subaru dropped their only hybrid for the 2017 model year.
http://www.greencarreports.com/news/1106428_subaru-crosstrek-hybrid-discontinued-for-2017-model-year
Yeah, hybrids are tough sale now. Gas is kept low, electrical models proliferate like mushrooms after rain and get better and better..... Hybrids steadily become passe....
1 - 9 of 9 Posts
About this Discussion
4 Participants
ukrkoz
Toyota Nation Forum
Full Forum Listing
