1 - 4 of 4 Posts
· 2002 Camry
I want to get a torque wrench for tighting my oil and transmission drain plug.
1. What is the proper torque for the transmission plug?
2. Is there a gasket for the plug?
3. What is the best way to measure fluid that drains out of your transmission so i put back the same amount.
4. what is a good torque wrench?
· 480 HP 2.4L = lying ricer
06 Camry LE 2AZFE A5
You don't need a torque wrench. Just tighten the plug reasonably. Don't measure the fluid coming out, it doesn't matter. Make sure that it's at the proper level when you fill it.
If you aren't satisfied with the information that I've given, you can EASILY check the online manual.
about 36 (lbf·ft). I use 33-34 just in case my torque wrench is not properly calibrated.
Mine has an aluminum gasket
Not the best approach if your transmission was filled incorrectly the previous time. 4 cyl Gen 5 Camry will need between 3.7 to 4.2 Qts. Just follow your owners manual and follow the procedure outlined on how to fill it to the correct level. You can also buy clear container with measurements markings to measure what came out of your transmission if that's what you really want to do.
Autozone and Advance Auto Parts sells them for 20-22 bucks. Napa and Sears have better ones. It all depends on how much you are willing to spend on a torque wrench.
Camry
^ There are two main types, beam type and click type. The click type is more convenient to use but also more prone to losing calibration and more delicate; meaning don't bang the thing around.
The beam type is useful in less situations because you have to be able to see the scale and you have to keep the handle centered on the lever. It is easier to maintain and keep it's calibration. It also tends to cost less than the click type.
1 - 4 of 4 Posts
