You can disable the automatic shutoff by locking the door from the inside of the vehicle or using the mechanical key to lock the door from the outside. Obviously, that means running the extension cord through a partially-opened window.On a separate note, I ran an extension cord from the highlander to the camper. Was able to run the fan overnight and in the morning a toaster. Was awesome as it kept the kiddos cool and fed. Nice feature Toyota! Now, send an over the air update that prevents the vehicle from auto shutoff after an hour!! I had to get up a couple times to restart the vehicle and turn on the inverters when I would rather sleep![]()
If you can what type of MPG were you obtaining when towing?I just pulled a pop up camper this last weekend rented from rvshare. Wanted to see how the hybrid system performed before buying one. The owner said it was about 2000 lbs, had about 500 lbs of stuff between the vehicle and car and 3 kids in the highlander.
I have a hybrid awd limited highlander and it did just fine. Used Toyota’s converter and 4 pin flat connector to get trailer lights and a the curt hitch for the trailer connection. No problems what so ever. I will be expanding to the 7 pin adapter to power a trailer with brakes in the future as I’m looking to get a 3000+ lb trailer soon. Either RPod 193, NoBo 16.6, or EPro 19BHS. I’m a fan of bunk houses. The rpod is over the limit but the other two are close.
Those trailers are all at the limit of the towing per Toyota so I’m not sure if I’ll pull the trigger and buy one or not. To me, it isn’t about stability as putting weight in the front of the trailer is positive in terms of stability margin, it is about total weight the hybrid power train can pull. Stability vs tongue weight is the constraint here IMO. This is because the gas highlander is the same wheelbase. Only relevant difference I see is the gas engine/transmission on towing capability.
Anyways, the next RV I rent will be heavier to see what the system can actually handle.
Have you been able to get this to work? I saw your post in the generator thread and tried to do it but it didn’t work. I did both linking with key and looking with window open from the inside of the highlander. Both failed and the car shutdown after an hour. I’d be interested in if anyone got this to work.You can disable the automatic shutoff by locking the door from the inside of the vehicle or using the mechanical key to lock the door from the outside. Obviously, that means running the extension cord through a partially-opened window.
It was a portion of the fuel tank but I would estimate 28 or so MPG while pulling it since I get 35MPG most of the time. I got 33mpg on that tank with mostly city driving and pulling a moving trailer too. So, I’d say it did pretty good pulling it.If you can what type of MPG were you obtaining when towing?
I’m still waiting for my Highlander Hybrid (ordered in February).Have you been able to get this to work? I saw your post in the generator thread and tried to do it but it didn’t work. I did both linking with key and looking with window open from the inside of the highlander. Both failed and the car shutdown after an hour. I’d be interested in if anyone got this to work.
Definitely try pulling a taller trailer before you make your buying decision. I have pulled a pop up all over the country with my Honda Odyssey (actually 500 lbs above the rated weight) with no issues because of the low profile. The tow vehicle cuts the air and the trailer comes along in the same air stream. In other towing scenarios I pulled an enclosed U-Haul trailer at 1/2 the weight of the camper with a front wall still lower and more aerodynamic than many travel trailers and it pulled harder than my camper and struggled to hold 65 mph on flat ground. Not a direct comparison of course, but worth noting. I have towed many other trailers over the last 40+ years and have always observed that frontal area is far more impactful on how a trailer tows than weight.I just pulled a pop up camper this last weekend rented from rvshare. Wanted to see how the hybrid system performed before buying one. The owner said it was about 2000 lbs, had about 500 lbs of stuff between the vehicle and car and 3 kids in the highlander.
Great insight. I’ll be sure to rent one before buying to see how it goes. Maybe still this summer.Definitely try pulling a taller trailer before you make your buying decision. I have pulled a pop up all over the country with my Honda Odyssey (actually 500 lbs above the rated weight) with no issues because of the low profile. The tow vehicle cuts the air and the trailer comes along in the same air stream. In other towing scenarios I pulled an enclosed U-Haul trailer at 1/2 the weight of the camper with a front wall still lower and more aerodynamic than many travel trailers and it pulled harder than my camper and struggled to hold 65 mph on flat ground. Not a direct comparison of course, but worth noting. I have towed many other trailers over the last 40+ years and have always observed that frontal area is far more impactful on how a trailer tows than weight.
Here is a photo.We purchased a 2020 Jayco Travel Trailer Baja SLX 16.6 Ft. (max loaded weight about 3,100 lbs.) Pulling it with our 2020 Highlander Hybrid model LE / AWD was no problem. The motor does work harder especially climbing mountain passes when driving to Bend Oregon from near Salem Oregon, quite an elevation change.
Indicated MPG from the dash was 14.8 MPG. On level ground at safe highway speeds, 55-60 MPG expect about 18-20 MPG. This trailer has a high profile, not very aerodynamic, as it is designed for off road camping. Our MPG is increasing now with over 2,000 miles on the odometer. Without the trailer at highway speeds, 55-65 MPH, mpg is 38-40 mpg. MPG gauge without the trailer filling up just north of Salem Oregon to our home in Seaside Oregon the dash read 42.8 MPG with 93.3 miles.When checking the odometer for accuracy on a 5 miles measured mile area on Interstate Highway 5, north of Salem Oregon the odometer reads slightly negative. So based on that if your odometer reads 100 miles you actually traveled 101.5 miles. I don't know if all 2020 Highlanders are off but I know ours is based on that. That 5 miles section was measured by the Oregon Dept. of Transportation just for that purpose of checking your odometer.
