1 - 6 of 6 Posts
G
Is there anyway to make the 12v accessory power stay on when the key is
not turned..
My '96 chevy cavalier had this feature, all chevy's do I believe.
It was just nice to have cell phones charged or would be killer to run
something from the bed of my truck. with out leaving the keys inside.
G
Discussion Starter · #2 ·
<[email protected]> wrote in message
news:[email protected]
> not turned..
What year and model Toyota truck do you have?
G
Discussion Starter · #3 ·
"bbtaco" <[email protected]> wrote in message
>> not turned..
2002 Tacoma double cab, TRD with 6 cylinder engine. Color: Black sand pearl.
G
Discussion Starter · #4 ·
I'll listen too. My 04 sr5 auto 4x4 has 3 power ports. I wish it was full
time like the Ford. A notebook and phone charger isnt going to kill the
battery that fast.
G
Discussion Starter · #5 ·
>not turned..
I put a 12 volt outlet in the bed of my Tundra. I drilled a small
hole in a waterproof ammo box (secured to the side of the bed with
bungee cords), put the outlet in and ran the wire from the box under
the rocker panel covers. I found a small space in the front of the
left front door frame and ran the wire through that (it doesn't pinch
the wire when the door is closed) and into a hot space in the fuse
box. I used an inline fuse and sealed the hole in the box with
silicone.
I've used this for about 5 years and had the bed half filled with snow
and mud but it always worked when I opened the box and plugged in what
ever I was using.
As long as you are using low amp stuff, like a cell phone charger, you
shouldn't have a problem.
Skip
G
Discussion Starter · #6 ·
"Doug Kanter" <[email protected]> wrote in message
>>> not turned..
> pearl.
I have a 2002 extended cab TRD with the V6 in Lunar Mist. I know this works
on the 2002 Tacomas. :) It should also work on any of the 2004 and earlier
Tacomas as they are basically the same truck. I do not know about the 2005
or newer models.
http://www.bajataco.com/Full-Time-Power.html A great site for Tacoma owners
is www.tacomaterritory.com
BBTaco
1 - 6 of 6 Posts
