1 - 1 of 1 Posts
Located in
Toyota: 4Runner RWD 4dr V6 SR5 RWD 4dr V6 SR5 New SUV Automatic Gasoline 4.0L V6 Cyl Magnetic Gray Metallic
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
Longo Toyota 3534 North Peck Road El Monte, CA 91731 844-249-2526 EBizAutos* 2016 Toyota 4Runner RWD 4dr V6 SR5 Request More Info Photos Photos Videos Videos Photo 1 of 30 VIN: JTEZU5JR0G5118452 Stock #: 1163553 Condition: New Transmission: 5 Spd Automatic Engine: 4.0L V6 CYLINDER Drivetrain: Rear Wheel Drive Exterior Color: Magnetic Gray Metallic Interior Color: Black/Graphite Photo Viewer View Other Auctions Email A Friend More Details Additional Photos Vehicle Overview What can you expect from the #1 volume auto dealership in the USA for 48 consecutive years? *The largest Inventory of Toyotas and Scions in the USA, up front pricing and a truly outstanding car buying experience.* Over 80% of our business comes from repeat and referral guests.* We invite you to experience the Longo Difference. * GET A NO HASSLE QUOTE If you would like a quote on this vehicle, please complete the inquiry form.* One of our Internet Managers will promptly send you a custom quote in writing.* We can also provide you with lease and finance terms.* Need financing?* We can help find the best finance options and help you take advantage of any factory programs.* We work with all credit types! * WE DELIVER We have the vehicle you want, but you can't make it to Longo?* No problem!* We will come to you with the vehicle and all the necessary paperwork.* Contact us for details. * AMENITIES We have a Starbucks, Subway, Verizon Store, AAA and Enterprise Car Rental on our premises for your convenience.* We have free Wi-Fi throughout the property and we even let you borrow IPADS to use while your vehicle is in service.* We have a 5 story structure where most of our inventory is stored.* Not only does this keep your next car protected from the elements, it also makes for a more comfortable shopping experience.* In one visit, you will understand why more Los Angelinos have allowed us to earn their business than any other dealer for 48 straight years.* * * * * * * Options & Packages OEM Code Description MSRP ADDITIONAL EQUIPMENT FB22 BLACK/GRAPHITE, LOW FABRIC SEAT TRIM $0.00 TH FABRIC-TRIMMED 50/50 SPLIT FOLD-FLAT 3RD ROW $805.00 QB KEEP IT WILD SAVINGS $-500.00 E5 EXHAUST TIP $90.00 CF CARPET FLOOR MATS & CARPET CARGO MAT $225.00 3T CARGO CROSS BARS $185.00 Features & Specifications Standard Features* – MECHANICAL Engine: 4.0L V6 DOHC SMPI Transmission: Electronic 5-Speed Automatic w/OD 3.727 Axle Ratio GVWR: 6,100 lbs Transmission w/Sequential Shift Control and Oil Cooler Rear-wheel drive 72-Amp/Hr 750CCA Maintenance-Free Battery Class III Towing w/Harness and Hitch 2 Skid Plates 1700# Maximum Payload Gas-pressurized shock absorbers Front And Rear Anti-Roll Bars Hydraulic Power-Assist Speed-Sensing Steering 23 Gal. Fuel Tank Single stainless steel exhaust Double wishbone front suspension w/coil springs Multi-link rear suspension w/coil springs 4-Wheel Disc Brakes w/4-Wheel ABS, Front And Rear Vented Discs, Brake Assist and Hill Hold Control Security System Pre-Wiring Brake Actuated Limited Slip Differential Vehicle Name : Toyota 4Runner Body Style : Sport Utility Drivetrain : Rear Wheel Drive Gross Axle Wt Rating - Front (lbs) : 2998 Gross Axle Wt Rating - Rear (lbs) : 3439 Gross Vehicle Weight Rating Cap (lbs) : 6100 Dead Weight Hitch - Max Trailer Wt. (lbs) : 5000 Dead Weight Hitch - Max Tongue Wt. (lbs) : 500 Wt Distributing Hitch - Max Trailer Wt. (lbs) : 5000 Wt Distributing Hitch - Max Tongue Wt. (lbs) : 750 Maximum Trailering Capacity (lbs) : 5000 Engine Type : Regular Unleaded V-6 Displacement : 4.0 L/241 Fuel System : Sequential MPI SAE Net Horsepower @ RPM : 270 @ 5600 SAE Net Torque @ RPM : 278 @ 4400 Trans Type : 5 Trans Description Cont. : Automatic w/OD First Gear Ratio :)1) : 3.52 Second Gear Ratio :)1) : 2.04 Third Gear Ratio :)1) : 1.40 Fourth Gear Ratio :)1) : 1.00 Fifth Gear Ratio :)1) : 0.72 Reverse Ratio :)1) : 3.22 Trans PTO Access : No Transfer Case Power Take Off : No Cold Cranking Amps @ 0* F (Primary) : 750 Cold Cranking Amps @ 0* F (2nd) : 750 Engine Oil Cooler : None Suspension Type - Front : Double Wishbone Suspension Type - Rear : Multi-Link Axle Type - Front : Independent Axle Type - Rear : Rigid Axle Axle Ratio :)1) - Front : 3.73 Axle Ratio :)1) - Rear : 3.73 Steering Type : Rack-Pinion Turning Diameter - Curb to Curb (ft) : 37.4 Brake ABS System : 4-Wheel Brake ABS System (Second Line) : 4-Wheel Disc - Front (Yes or ) : Yes Disc - Rear (Yes or ) : Yes Front Brake Rotor Diam x Thickness (in) : 13.3 Rear Brake Rotor Diam x Thickness (in) : 12.3 + EXTERIOR Wheels: 17" x 7.0" 6-Spoke Alloy Tires: P265/70R17 Mud & Snow Steel spare wheel Full-Size Spare Tire Stored Underbody w/Crankdown Clearcoat paint Body-Colored Front Bumper w/1 Tow Hook Body-colored rear step bumper Chrome Bodyside Insert, Rocker Panel Extensions And Body-Colored Fender Flares Black Side Windows Trim, Black Front Windshield Trim And Black Rear Window Trim Chrome door handles Body-Colored Power Heated Side Mirrors w/Manual Folding Power Rear Window w/Fixed Interval Wiper and Defroster Deep tinted glass Variable Intermittent Wipers w/Heated Wiper Park Fully Galvanized Steel Panels Lip Spoiler Grille w/Body-Colored Bar Liftgate Rear Cargo Access Tailgate/Rear Door Lock Included w/Power Door Locks Roof Rack Rails Only Auto Off Projector Beam Halogen Daytime Running Headlamps Front fog lamps Perimeter/Approach Lights LED brakelights Front Tire Size : P265/70SR17 Rear Tire Size : P265/70SR17 Spare Tire Size : Full-size Front Wheel Size (in) : 17 x 7 Rear Wheel Size (in) : 17 x 7 Spare Wheel Size (in) : Full-size Front Wheel Material : Aluminum Rear Wheel Material : Aluminum Spare Wheel Material : Steel Wheelbase (in) : 109.8 Length, Overall (in) : 190.2 Width, Max w/o mirrors (in) : 75.8 Height, Overall (in) : 71.5 Track Width, Front (in) : 63.2 Track Width, Rear (in) : 63.2 Min Ground Clearance (in) : 9 Cargo Volume to Seat 1 (ft3) : 89.7 Cargo Volume to Seat 2 (ft3) : 47.2 Cargo Volume to Seat 3 (ft3) : 47.2 + ENTERTAINMENT Radio: Entune Audio Plus w/Connected Navigation -inc: Entune Multimedia bundle (6.1" high resolution touch-screen display, AM/FM CD player, MP3/WMA playback capability, 8-speakers, auxiliary audio jack, USB 2.0 port w/iPod connectivity and control, advanced voice recognition, hands-free phone capability, phone book access and music streaming via Bluetooth wireless technology), connected navigation Scout GPS Link app, Siri Eyes Free, SiriusXM All Access Radio w/3-month complimentary trial, HD Radio, HD traffic and weather in major metro areas and integrated backup camera display w/projected path, Radio w/Seek-Scan, Clock, Aux Audio Input Jack, Steering Wheel Controls and Voice Activation 8 Speakers Window grid diversity antenna 1 LCD Monitor In The Front Real-Time Traffic Display + INTERIOR Front Bucket Seats -inc: 8-way power-adjustable driver's seat w/power lumbar support and 4-way adjustable front passenger seat 8-Way Driver Seat 4-Way Passenger Seat 40-20-40 Folding Split-Bench Front Facing Manual Reclining Fold Forward Seatback Rear Seat Manual tilt/telescoping steering column Gauges -inc: Speedometer, Odometer, Voltmeter, Engine Coolant Temp, Tachometer, Trip Odometer and Trip Computer Power Rear Windows And Fixed 3rd Row Windows 5 Person Seating Capacity Leather steering wheel Front cupholder Rear cupholder Valet Function Remote Keyless Entry w/Integrated Key Transmitter, 4 Door Curb/Courtesy, Illuminated Entry, Illuminated Ignition Switch and Panic Button Cruise control w/steering wheel controls Manual air conditioning HVAC -inc: Underseat Ducts And Console Ducts Locking glove box Driver foot rest Interior Trim -inc: Metal-Look Instrument Panel Insert, Metal-Look Door Panel Insert, Metal-Look Console Insert And Metal-Look Interior Accents Full cloth headliner Leatherette door trim insert Leather gear shift knob Low Fabric Seat Trim Day-night rearview mirror Driver And Passenger Visor Vanity Mirrors w/Driver And Passenger Illumination, Driver And Passenger Auxiliary Mirror Full Floor Console w/Covered Storage, Mini Overhead Console w/Storage, 5 12V DC Power Outlets and 1 AC Power Outlet Front map lights Fade-to-off interior lighting Full Carpet Floor Covering Carpet Floor Trim Cargo Space Lights FOB Controls -inc: Windows Instrument Panel Covered Bin, Driver / Passenger And Rear Door Bins Power 1st Row Windows w/Front And Rear 1-Touch Up/Down Delayed Accessory Power Power Door Locks w/Autolock Feature Systems Monitor Trip computer Outside temp gauge Analog Display Manual Anti-Whiplash Adjustable Front Head Restraints and Manual Adjustable Rear Head Restraints Front Center Armrest And Rear Center Armrest 2 Seatback Storage Pockets Engine immobilizer 5 12V DC Power Outlets and 1 AC Power Outlet Air filtration Passenger Capacity : 5 Front Head Room (in) : 39.3 Front Leg Room (in) : 41.7 Front Shoulder Room (in) : 57.8 Front Hip Room (in) : 56.5 Second Head Room (in) : 38.6 Second Leg Room (in) : 32.9 Second Shoulder Room (in) : 57.8 Second Hip Room (in) : 55.7 + SAFETY Electronic stability control (ESC) ABS And Driveline Traction Control Side Impact Beams Dual Stage Driver And Passenger Seat-Mounted Side Airbags Low tire pressure warning Dual Stage Driver And Passenger Front Airbags Curtain 1st, 2nd And 3rd Row Airbags Airbag Occupancy Sensor Driver And Passenger Knee Airbag Rear child safety locks Outboard Front Lap And Shoulder Safety Belts -inc: Rear Center 3 Point, Height Adjusters and Pretensioners Back-up camera + EPA Fuel Economy & Specification EPA Greenhouse Gas Score : 4.0 Fuel Economy Est-Combined (MPG) : 19 EPA Fuel Economy Est - City (MPG) : 17 EPA Fuel Economy Est - Hwy (MPG) : 22 Tons/yr of CO2 Emissions @ 15K mi/year : 9.3 Fuel Tank Capacity, Approx (gal) : 23 Fuel Tank Location : Midship Aux Fuel Tank Location : Midship + Additional Features 4.0L V6 DOHC SMPI, Rear-Wheel Drive, Front Bucket Seats -inc: 8-way power-adjustable driver's seat w/power lumbar support and 4-way adjustable front passenger seat, 8-Way Driver Seat, 4-Way Passenger Seat, 40-20-40 Folding Split-Bench Front Facing Manual Reclining Fold Forward Seatback Rear Seat, Power Rear Windows and Fixed 3rd Row Windows, 5 Person Seating Capacity, Front Cupholder, Rear Cupholder, 5 12V DC Power Outlets, Valet Function, HVAC -inc: Underseat Ducts and Console Ducts, Locking Glove Box, Driver Foot Rest, Interior Trim -inc: Metal-Look Instrument Panel Insert, Full Cloth Headliner, Leatherette Door Trim Insert, Leather Gear Shift Knob, Day-Night Rearview Mirror, Driver And Passenger Visor Vanity Mirrors w/Driver And Passenger Illumination, Full Floor Console w/Covered Storage, Front Map Lights, Fade-To-Off Interior Lighting, Full Carpet Floor Covering, Carpet Floor Trim, Cargo Space Lights, Instrument Panel Covered Bin, Power 1st Row Windows w/Front And Rear 1-Touch Up/Down, Delayed Accessory Power, Systems Monitor, Outside Temp Gauge, Analog Display, Manual Anti-Whiplash Adjustable Front Head Restraints and Manual Adjustable Rear Head Restraints, Front Center Armrest and Rear Center Armrest, 2 Seatback Storage Pockets, Engine Immobilizer, 5 12V DC Power Outlets and 1 AC Power Outlet, Air Filtration, black/graphite, radio: entune premium audio with navigation, Tires: P265/70R17 Mud & Snow, Full-Size Spare Tire Stored Underbody w/Crankdown, Clearcoat Paint, Body-Colored Front Bumper w/1 Tow Hook, Chrome Bodyside Insert, Black Side Windows Trim, Chrome Door Handles, 2 Seatback Storage Pockets, 4-Way Passenger Seat, 40-20-40 Folding Split-Bench Front Facing Manual Reclining Fold Forward Seatback Rear Seat, 5 12V DC Power Outlets, 5 12V DC Power Outlets and 1 AC Power Outlet, 5 Person Seating Capacity, 8-Way Driver Seat, Air Filtration, Analog Display, black/graphite low fabric seat trim, Cargo Space Lights, Carpet Floor Trim, Day-Night Rearview Mirror, Delayed Accessory Power, Driver And Passenger Visor Vanity Mirrors w/Driver And Passenger Illumination Driver And Passenger Auxiliary Mirror, Driver Foot Rest, Engine Immobilizer, Fade-To-Off Interior Lighting, Front Bucket Seats -inc: 8-way power-adjustable driver's seat w/power lumbar support and 4-way adjustable front passenger seat, Front Center Armrest and Rear Center Armrest, Front Cupholder, Front Map Lights, Full Carpet Floor Covering, Full Cloth Headliner, Full Floor Console w/Covered Storage Mini Overhead Console w/Storage 5 12V DC Power Outlets and 1 AC Power Outlet, HVAC -inc: Underseat Ducts and Console Ducts, Instrument Panel Covered Bin Driver / Passenger And Rear Door Bins, Interior Trim -inc: Metal-Look Instrument Panel Insert Metal-Look Door Panel Insert Metal-Look Console Insert and Metal-Look Interior Accents, Leather Gear Shift Knob, Leatherette Door Trim Insert, Locking Glove Box, Manual Anti-Whiplash Adjustable Front Head Restraints and Manual Adjustable Rear Head Restraints, Outside Temp Gauge, Power 1st Row Windows w/Front And Rear 1-Touch Up/Down, Power Rear Windows and Fixed 3rd Row Windows, radio: entune premium audio with navigation, Rear Cupholder, Systems Monitor, Valet Function, Black Side Windows Trim Black Front Windshield Trim and Black Rear Window Trim, Body-Colored Front Bumper w/1 Tow Hook, Chrome Bodyside Insert Rocker Panel Extensions and Body-Colored Fender Flares, Chrome Door Handles, Clearcoat Paint, Full-Size Spare Tire Stored Underbody w/Crankdown, Grille w/Body-Colored Bar, LED Brakelights, Liftgate Rear Cargo Access, Lip Spoiler, Perimeter/Approach Lights, Tires: P265/70R17 Mud & Snow, Airbag Occupancy Sensor, Back-Up Camera, Driver And Passenger Knee Airbag, Dual Stage Driver And Passenger Front Airbags, Low Tire Pressure Warning, Outboard Front Lap And Shoulder Safety Belts -inc: Rear Center 3 Point Height Adjusters and Pretensioners, Rear Child Safety Locks, Side Impact Beams Buyer Resources Terms of Sale Overview We reserve the right to end this listing at anytime should the vehicle no longer be available for sale. The following terms of sale apply to all of our listings. Contact Internet Manager eBay for more information Toll-Free:*** 844-249-2526 Request More Info Warranty Information ? FULL FACTORY WARRANTY ? EXTENDED WARRANTY AVAILABLE This Vehicle is Covered by the Full Factory Warranty. Contact us for more information on the factory warranty. If you are interested in one of our vehicles and have a question on available warranties, please contact us! Contact us or click the "More Photos and Detailed Description" link above for more information. Longo Toyota El Monte CA Contact Internet Manager eBay Toll-Free: 844-249-2526 Contact Internet Manager eBay for more information Toll-Free: 844-249-2526 Request More Info It is the customer's sole responsibility to verify the existence and condition of any equipment listed. Neither the dealership nor eBizAutos is responsible for misprints on prices or equipment. It is the customer's sole responsibility to verify the accuracy of the prices with the dealer, including the pricing for all added accessories. Copyright © 2001-2016 eBizAutos.**All Rights Reserved. * eBay Motors Software*by eBizAutos * Counter Provided by eBizAutos.com
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
1 - 1 of 1 Posts
