1 - 5 of 5 Posts
Hey,
I have problem with my toyota avensis 2004, 95kw 1.8 petrol.
After gearbox was changed (manual) other issues started to appear. Such as - when car is worm, while accelerating with 1st gear car is shaking. On 2nd, 3rd, 4th and 5th everything seems to be good.
While car is cold, there are no issues with this.
What could be the issue?
Car gives me no errors besides catalyst P0420
Hey,
yeah i have the same problem and i found out the transmission mount, i lift up the car and i let someone give the first gear and release the clutch the transmission begin to move around a lot
Hey,
320907
this mount was the most worn one which make the transmission to shake but since changing mount you need to change all because if you change the defective ome the other will worn out faster
also check inner cv joint may be so worn that the tripod inside shake back and forth which make this vibration
1 - 5 of 5 Posts
