Sounds like a bad / stuck thermostat.infinityx said:
I don't think its the head gasket.
Unless one or more of your pistons is drinking water and white smoke is pouring out the tailpipe, the head gasket is not the cause.
Sounds like a bad / stuck thermostat.infinityx said:Symptoms:
when driving if you accelarate a lot it would start reaching red hot but then drop back down to half.
I don't think its the head gasket.the mechanic said its the head gastket and also the head ($1k to fix more if the head has to be replaced)
Yes.infinityx said:would the thermostat cause the boiling and the water to go from the radiator to the catchment then overflow out the car?
Thats because coolant (antifreeze) raises the boiling point.the car seems to stay on middle a little longer with coolant than when i was using plain water.
Time to find a new mechanic.infinityx said:my mechanic pressed the accelarator with the radiator cap open and all the water went flying. he said, that means the head gasket is blown.
is this true?
http://www.autozone.com/servlet/UiB..._us/0900823d/80/13/e9/8f/0900823d8013e98f.jspi'll try the thermostat thing..i'll google how to change it. cause i am a total noob to cars right now.
Does it say anything else about the leak? IE: low compression or water in cylinder?infinityx said:this is what they said
cylinder head gasket leaking into no 2 cylinder, requires replacement
app $2050
could they be wrong? or does this mean there is definately a gasket problem.
:wtf:infinityx said:he was talking about something to do with combustion and replacing the rm oil seal.
also the guy said the engin was perffectly fine. they also did a compression test aparently.
You either have a 3S-FE (I4) or 2VZ-FE (V6).i had a look at that site and the guide on how to replace the thermostat.
i just have to find what type of engine i have cause there were diffrent types..
Theres a plug on the thermostat housing that you'll need to disconnect. Its for the cold start timing switch.infinityx said:so no need to remove the other wires connected to the thermostat?
Buy a gasket for the thermostat too.cool now to go and buy a thermostat and more coolant![]()
