1 - 10 of 10 Posts
Hi guys, i owned toyota corona st210 with 3sfe engine and 4 speed automatic transmission.
I got problem on my corona that 3 workshop so far can't fix it
Here the problem:
When first start engine warming up ABS light on
When moving car speedometer not working, ABS still light on but this time Engine Check light on and O/D Off light is flashing
Diagnostic using scan tools it show #42 Vehicle Speed Sensor
Mechanic try to find Speed Sensor on transmission but they cant find any on transmission and said this ST210 dont have? Is it?
Thanks hopefully someone can help me or otherwise i need to send it to scrapyard 馃槬
Toyota Collector
From what I can gather there is no speed sensor on the transmission the ECU uses the 4 wheel speed (ABS) sensors. But without your VIN or frame code I can't say for sure.
Sir it was ST210R-AEPNK
Toyota Corona 2.0GLi 1997
2.0L Dohc 16 Valve
Automatic Transmission
Thanks
Discussion Starter #6
2.0L Dohc 16 Valve
Thanks
I don't see any speed sensors on the transmission.
Yes that what was mechanic said but on diagnostic tool it was Vehicle Speed Sensor fault
Abs wheel sensor front both read 1.450-1.465ohm and rear 1.235-1.239ohm
Is it possible faulty speedometer? Got one shop ask to change speedometer.
A lot of things start with a wiring diagram that no one uses.
1 - 10 of 10 Posts
