1 - 4 of 4 Posts
Toyota Echo automatic 2004 Engine swap
Greeting to all.
I have a question which i am unable to find any answers .i hope i could get some here .Recently my echo engine (with automatic gearbox)got damaged by broken valve , broken piston and head .
so i took it to the mechanic ,he said its much cheaper to replace the whole engine with the same engine from the scrapped car .So i finally found one after a long search in the scrap yard as echo is getting rarer ,but the problem is that the scrapped car echo is with a Manual gearbox .will this engine be a correct fit to my automatic gearbox ?
Should i need to change any parts so that my car can use this engine . the Engine is 2nz-fe
regards
roby
Dear chuckoff
Thank you for your reply, my old car is automatic and the donor car is a manual will there be any issues.
1 - 4 of 4 Posts
About this Discussion
3 Participants
Old Mechanic
Toyota Nation Forum
Full Forum Listing
