I went with older 4x4 16" Tacoma wheels (think they were from a 2000 I believe). Most of the more modern wheels from Toyota trucks and SUVs didn't have enough back spacing. Some of the early Tundras looked like they would work too.
Edit: If the ones you're getting are the exact same ones in the picture (believe they look like
these), then they should fit perfectly since they have a 15mm offset just like
these ones I used.
EDIT 2: If they're the ones in the photo you have then they're 17s, but if they're 16s like the guy in the other thread has, then 235/65/r16 tires work perfectly on a 2wd. Speedo is like .1 MPH off at 70 MPH LOL. Can't get any better than that. Plus that size is readily available. Was having trouble finding the factory size 15" tires anywhere which kind of influenced me to go through with the upgrade a couple of years ago.
