1 - 1 of 1 Posts
Located in
Toyota : Highlander FWD 4dr V6 XLE FWD 4dr V6 XLE New SUV Automatic Gasoline 3.5L V6 Cyl Blizzard Pearl
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
Longo Toyota 3534 North Peck Road El Monte, CA 91731 844-249-2526 EBizAutos* 2016 Toyota Highlander FWD 4dr V6 XLE Request More Info Photos Photos Videos Videos Photo 1 of 30 VIN: 5TDKKRFHXGS128533 Stock #: 1163767 Condition: New Transmission: 6 Spd Automatic Engine: 3.5L V6 CYLINDER Drivetrain: Front Wheel Drive Exterior Color: Blizzard Pearl Interior Color: Black Photo Viewer View Other Auctions Email A Friend More Details Additional Photos Vehicle Overview What can you expect from the #1 volume auto dealership in the USA for 48 consecutive years? *The largest Inventory of Toyotas and Scions in the USA, up front pricing and a truly outstanding car buying experience.* Over 80% of our business comes from repeat and referral guests.* We invite you to experience the Longo Difference. * GET A NO HASSLE QUOTE If you would like a quote on this vehicle, please complete the inquiry form.* One of our Internet Managers will promptly send you a custom quote in writing.* We can also provide you with lease and finance terms.* Need financing?* We can help find the best finance options and help you take advantage of any factory programs.* We work with all credit types! * WE DELIVER We have the vehicle you want, but you can't make it to Longo?* No problem!* We will come to you with the vehicle and all the necessary paperwork.* Contact us for details. * AMENITIES We have a Starbucks, Subway, Verizon Store, AAA and Enterprise Car Rental on our premises for your convenience.* We have free Wi-Fi throughout the property and we even let you borrow IPADS to use while your vehicle is in service.* We have a 5 story structure where most of our inventory is stored.* Not only does this keep your next car protected from the elements, it also makes for a more comfortable shopping experience.* In one visit, you will understand why more Los Angelinos have allowed us to earn their business than any other dealer for 48 straight years.* * * * * * * Options & Packages OEM Code Description MSRP SEAT TRIM LB20 BLACK, LEATHER SEAT MATERIAL $0.00 ADDITIONAL EQUIPMENT PC SPECIAL COLOR $395.00 PORT INSTALLED OPTIONS CT CARPET FLOOR MATS & CARGO LINER $230.00 Features & Specifications Standard Features* – MECHANICAL Engine: 3.5L V6 DOHC 24-Valve w/Dual VVT-i Transmission: Electronic 6-Speed Automatic w/OD -inc: ECT-i, sequential shift mode and snow mode 4.154 Axle Ratio GVWR: 5,840 lbs Transmission w/Oil Cooler Front-wheel drive Engine oil cooler 150 amp alternator Towing w/Harness 1455# Maximum Payload Gas-pressurized shock absorbers Front And Rear Anti-Roll Bars Electric Power-Assist Speed-Sensing Steering 19.2 Gal. Fuel Tank Single stainless steel exhaust Strut Front Suspension w/Coil Springs Double Wishbone Rear Suspension w/Coil Springs 4-Wheel Disc Brakes w/4-Wheel ABS, Front Vented Discs, Brake Assist and Hill Hold Control Vehicle Name : Toyota Highlander Body Style : Sport Utility Drivetrain : Front Wheel Drive EPA Classification : Small Sport Utility Vehicles 2WD Base Curb Weight (lbs) : 4310 Dead Weight Hitch - Max Trailer Wt. (lbs) : 5000 Dead Weight Hitch - Max Tongue Wt. (lbs) : 500 Wt Distributing Hitch - Max Trailer Wt. (lbs) : 5000 Wt Distributing Hitch - Max Tongue Wt. (lbs) : 750 Maximum Trailering Capacity (lbs) : 5000 Engine Type : Regular Unleaded V-6 Displacement : 3.5 L/211 Fuel System : Sequential MPI SAE Net Horsepower @ RPM : 270 @ 6200 SAE Net Torque @ RPM : 248 @ 4700 Trans Type : 6 Trans Description Cont. : Automatic w/OD First Gear Ratio :)1) : 3.30 Second Gear Ratio :)1) : 1.90 Third Gear Ratio :)1) : 1.42 Fourth Gear Ratio :)1) : 1.00 Fifth Gear Ratio :)1) : 0.71 Sixth Gear Ratio :)1) : 0.61 Reverse Ratio :)1) : 4.15 Final Drive Axle Ratio :)1) : 4.15 Maximum Alternator Capacity (amps) : 150 Suspension Type - Front : Strut Suspension Type - Rear : Double Wishbone Suspension Type - Front (Cont.) : Strut Suspension Type - Rear (Cont.) : Double Wishbone Steering Type : Rack-Pinion Turning Diameter - Curb to Curb (ft) : 38.7 Brake ABS System : 4-Wheel Disc - Front (Yes or ) : Yes Disc - Rear (Yes or ) : Yes Front Brake Rotor Diam x Thickness (in) : 12.9 Rear Brake Rotor Diam x Thickness (in) : 12.2 + EXTERIOR Wheels: 18" Split 5-Spoke Machined-Face Alloy -inc: gunmetal grey finish and black center caps Tires: P245/60R18 105S AS Wheels w/Gray Accents Steel spare wheel Compact Spare Tire Stored Underbody w/Crankdown Clearcoat paint Express Open/Close Sliding And Tilting Glass 1st Row Sunroof w/Sunshade Body-colored front bumper Body-Colored Rear Bumper w/Black Rub Strip/Fascia Accent Black Wheel Well Trim Chrome Side Windows Trim Body-colored door handles Body-Colored Power Heated Side Mirrors w/Manual Folding and Turn Signal Indicator Flip-Up Rear Window w/Fixed Interval Wiper and Defroster Deep tinted glass Variable Intermittent Wipers w/Heated Wiper Park Fully Galvanized Steel Panels Lip Spoiler Black grille w/chrome surround Power Liftgate Rear Cargo Access Tailgate/Rear Door Lock Included w/Power Door Locks Roof Rack Rails Only Fully Automatic Projector Beam Halogen Daytime Running Headlamps w/Delay-Off Front fog lamps Front Tire Size : P245/60SR18 Rear Tire Size : P245/60SR18 Spare Tire Size : Compact Front Wheel Size (in) : 18 x 7.5 Rear Wheel Size (in) : 18 x 7.5 Spare Wheel Size (in) : Compact Front Wheel Material : Aluminum Rear Wheel Material : Aluminum Spare Wheel Material : Steel Wheelbase (in) : 109.8 Length, Overall (in) : 191.1 Width, Max w/o mirrors (in) : 75.8 Height, Overall (in) : 68.1 Track Width, Front (in) : 64.4 Track Width, Rear (in) : 64.2 Min Ground Clearance (in) : 8 Cargo Area Length @ Floor to Seat 3 (in) : 13.8 Cargo Volume to Seat 1 (ft3) : 83.2 Cargo Volume to Seat 2 (ft3) : 42.3 Cargo Volume to Seat 3 (ft3) : 13.8 + ENTERTAINMENT Radio: Entune Premium Audio w/Nav & App Suite -inc: the Entune Multimedia Bundle (8-inch high resolution touch-screen w/split screen display, AM/FM CD player, MP3/WMA playback capability, six speakers, auxiliary audio jack, USB 2.0 port w/iPod connectivity and control, advanced voice recognition, hands-free phone capability, phone book access and music streaming via Bluetooth wireless technology), Siri Eyes Free, Entune App Suite, Intelligent Touch Controls, SiriusXM Radio w/3-month complimentary trial, HD radio, HD predictive traffic and doppler weather overlay, AM/FM cache radio, Gracenotes album cover art, and integrated back up camer display w/projected path Radio w/Seek-Scan, Clock, Speed Compensated Volume Control and Steering Wheel Controls Window grid diversity antenna + INTERIOR Front Bucket Seats -inc: 8-way power adjustable driver's seat w/power thigh and lumbar support and 4-way passenger seat 60-40 Folding Split-Bench Front Facing Manual Reclining Fold Forward Seatback Rear Seat w/Manual Fore/Aft Manual tilt/telescoping steering column Gauges -inc: Speedometer, Odometer, Engine Coolant Temp, Tachometer, Trip Odometer And Trip Computer Power Rear Windows, Fixed 3rd Row Windows And w/Manual Sun Blinds 8 Person Seating Capacity Fixed 60-40 Split-Bench SofTex Leatherette 3rd Row Seat Front, Manual Recline, Manual Fold Into Floor, 3 Manual and Adjustable Head Restraints Leather/Metal-Look Steering Wheel Front cupholder Rear cupholder Valet Function Remote Keyless Entry w/4 Door Curb/Courtesy, Illuminated Entry, Illuminated Ignition Switch and Panic Button Remote Releases -Inc: Power Trunk/Hatch, Mechanical Fuel and Keyfob Rear Window Proximity Key For Doors And Push Button Start Garage Door Transmitter Cruise control w/steering wheel controls Rear HVAC w/Separate Controls HVAC -inc: Underseat Ducts And Headliner/Pillar Ducts Dual Zone Front Automatic Air Conditioning Locking glove box Driver foot rest Full cloth headliner Leatherette door trim insert Leather/Metal-Look Gear Shift Knob Interior Trim -inc: Metal-Look Instrument Panel Insert, Metal-Look Door Panel Insert, Chrome And Metal-Look Interior Accents Leather seat material Driver And Passenger Visor Vanity Mirrors w/Driver And Passenger Illumination, Driver And Passenger Auxiliary Mirror Day-Night Auto-Dimming Rearview Mirror Full Floor Console w/Covered Storage, Mini Overhead Console w/Storage, Conversation Mirror, 3 12V DC Power Outlets and 1 AC Power Outlet Front And Rear Map Lights Fade-to-off interior lighting Full Carpet Floor Covering Carpet Floor Trim Trunk/Hatch Auto-Latch Cargo Space Lights FOB Controls -inc: Trunk/Hatch/Tailgate Instrument Panel Bin, Driver / Passenger And Rear Door Bins Power 1st Row Windows w/Driver And Passenger 1-Touch Up/Down Delayed Accessory Power Power Door Locks w/Autolock Feature Systems Monitor Trip computer Outside temp gauge Analog Display Manual Adjustable Front Head Restraints And Manual Adjustable Rear Head Restraints Front center armrest 2 Seatback Storage Pockets Seats w/Leatherette Back Material Driver And Passenger Heated-Cushion, Driver And Passenger Heated-Seatback Engine immobilizer Perimeter alarm Air filtration 3 12V DC Power Outlets And 1 AC Power Outlet Passenger Capacity : 8 Passenger Volume (ft3) : 142.2 Front Head Room (in) : 39.5 Front Leg Room (in) : 44.2 Front Shoulder Room (in) : 59.3 Front Hip Room (in) : 57.2 Second Head Room (in) : 39.6 Second Leg Room (in) : 38.4 Second Shoulder Room (in) : 59.6 Second Hip Room (in) : 57.1 Third Head Room (in) : 35.9 Third Leg Room (in) : 27.7 Third Shoulder Room (in) : 55 Third Hip Room (in) : 45.6 + SAFETY Electronic stability control (ESC) ABS And Driveline Traction Control Side Impact Beams Dual Stage Driver And Passenger Seat-Mounted Side Airbags Low tire pressure warning Dual Stage Driver And Passenger Front Airbags Curtain 1st, 2nd And 3rd Row Airbags Airbag Occupancy Sensor Driver Knee Airbag and Passenger Cushion Front Airbag Rear child safety locks Outboard Front Lap And Shoulder Safety Belts -inc: Rear Center 3 Point, Height Adjusters and Pretensioners Back-up camera + EPA Fuel Economy & Specification Fuel Economy Est-Combined (MPG) : 21 (Est) EPA Fuel Economy Est - City (MPG) : 19 (Est) EPA Fuel Economy Est - Hwy (MPG) : 25 (Est) Tons/yr of CO2 Emissions @ 15K mi/year : 8.6 (Est) Fuel Tank Capacity, Approx (gal) : 19.2 + Additional Features 3.5L V6 DOHC 24-Valve w/Dual VVT-i, Front-Wheel Drive, Front Bucket Seats -inc: 8-way power adjustable driver's seat w/power thigh and lumbar support and 4-way passenger seat, Power Rear Windows, 8 Person Seating Capacity, Fixed 60-40 Split-Bench SofTex Leatherette 3rd Row Seat Front, Leather/Metal-Look Steering Wheel, Front Cupholder, Rear Cupholder, Valet Function, Remote Releases -Inc: Power Trunk/Hatch, Proximity Key For Doors And Push Button Start, Rear HVAC w/Separate Controls, HVAC -inc: Underseat Ducts and Headliner/Pillar Ducts, Locking Glove Box, Driver Foot Rest, Full Cloth Headliner, Leatherette Door Trim Insert, Leather/Metal-Look Gear Shift Knob, Interior Trim -inc: Metal-Look Instrument Panel Insert, Driver And Passenger Visor Vanity Mirrors w/Driver And Passenger Illumination, Day-Night Auto-Dimming Rearview Mirror, Full Floor Console w/Covered Storage, Front And Rear Map Lights, Fade-To-Off Interior Lighting, Full Carpet Floor Covering, Carpet Floor Trim, Trunk/Hatch Auto-Latch, Cargo Space Lights, Instrument Panel Bin, Power 1st Row Windows w/Driver And Passenger 1-Touch Up/Down, Delayed Accessory Power, Systems Monitor, Outside Temp Gauge, Analog Display, Manual Adjustable Front Head Restraints and Manual Adjustable Rear Head Restraints, Front Center Armrest, 2 Seatback Storage Pockets, Engine Immobilizer, 3 12V DC Power Outlets, Air Filtration, 3 12V DC Power Outlets and 1 AC Power Outlet, black, Tires: P245/60R18 105S AS, Compact Spare Tire Stored Underbody w/Crankdown, Clearcoat Paint, 2 Seatback Storage Pockets, 3 12V DC Power Outlets, 3 12V DC Power Outlets and 1 AC Power Outlet, 8 Person Seating Capacity, Air Filtration, Analog Display, black leather seat material, Cargo Space Lights, Carpet Floor Trim, Day-Night Auto-Dimming Rearview Mirror, Delayed Accessory Power, Driver And Passenger Visor Vanity Mirrors w/Driver And Passenger Illumination Driver And Passenger Auxiliary Mirror, Driver Foot Rest, Engine Immobilizer, Fade-To-Off Interior Lighting, Fixed 60-40 Split-Bench SofTex Leatherette 3rd Row Seat Front Manual Recline Manual Fold Into Floor 3 Manual and Adjustable Head Restraints, Front And Rear Map Lights, Front Bucket Seats -inc: 8-way power adjustable driver's seat w/power thigh and lumbar support and 4-way passenger seat, Front Center Armrest, Front Cupholder, Full Carpet Floor Covering, Full Cloth Headliner, Full Floor Console w/Covered Storage Mini Overhead Console w/Storage Conversation Mirror 3 12V DC Power Outlets and 1 AC Power Outlet, HVAC -inc: Underseat Ducts and Headliner/Pillar Ducts, Instrument Panel Bin Driver / Passenger And Rear Door Bins, Interior Trim -inc: Metal-Look Instrument Panel Insert Metal-Look Door Panel Insert Chrome And Metal-Look Interior Accents, Leather/Metal-Look Gear Shift Knob, Leather/Metal-Look Steering Wheel, Leatherette Door Trim Insert, Locking Glove Box, Manual Adjustable Front Head Restraints and Manual Adjustable Rear Head Restraints, Outside Temp Gauge, Power 1st Row Windows w/Driver And Passenger 1-Touch Up/Down, Power Rear Windows Fixed 3rd Row Windows and w/Manual Sun Blinds, Proximity Key For Doors And Push Button Start, Rear Cupholder, Rear HVAC w/Separate Controls, Remote Releases -Inc: Power Trunk/Hatch Mechanical Fuel and Keyfob Rear Window, Systems Monitor, Trunk/Hatch Auto-Latch, Valet Function, Black Grille w/Chrome Surround, Black Wheel Well Trim, Body-Colored Door Handles, Body-Colored Front Bumper, Body-Colored Power Heated Side Mirrors w/Manual Folding and Turn Signal Indicator, Body-Colored Rear Bumper w/Black Rub Strip/Fascia Accent, Chrome Side Windows Trim, Clearcoat Paint, Compact Spare Tire Stored Underbody w/Crankdown, Fully Automatic Projector Beam Halogen Daytime Running Headlamps w/Delay-Off, Lip Spoiler, Power Liftgate Rear Cargo Access, Tires: P245/60R18 105S AS, Airbag Occupancy Sensor, Back-Up Camera, Driver Knee Airbag and Passenger Cushion Front Airbag, Dual Stage Driver And Passenger Front Airbags, Low Tire Pressure Warning, Outboard Front Lap And Shoulder Safety Belts -inc: Rear Center 3 Point Height Adjusters and Pretensioners, Rear Child Safety Locks, Side Impact Beams Buyer Resources Terms of Sale Overview We reserve the right to end this listing at anytime should the vehicle no longer be available for sale. The following terms of sale apply to all of our listings. Contact Internet Manager eBay for more information Toll-Free:*** 844-249-2526 Request More Info Warranty Information ? FULL FACTORY WARRANTY ? EXTENDED WARRANTY AVAILABLE This Vehicle is Covered by the Full Factory Warranty. Contact us for more information on the factory warranty. If you are interested in one of our vehicles and have a question on available warranties, please contact us! Contact us or click the "More Photos and Detailed Description" link above for more information. Longo Toyota El Monte CA Contact Internet Manager eBay Toll-Free: 844-249-2526 Contact Internet Manager eBay for more information Toll-Free: 844-249-2526 Request More Info It is the customer's sole responsibility to verify the existence and condition of any equipment listed. Neither the dealership nor eBizAutos is responsible for misprints on prices or equipment. It is the customer's sole responsibility to verify the accuracy of the prices with the dealer, including the pricing for all added accessories. Copyright © 2001-2015 eBizAutos.**All Rights Reserved. * eBay Motors Software*by eBizAutos * Counter Provided by eBizAutos.com
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
1 - 1 of 1 Posts
