1 - 4 of 4 Posts
I have 2009 Toyota Matrix which has door ajar light stays on, therefore the dome lights do does not turn off and I can not use the keyfeb to lock the door but I can unlock it. As a result my BCM stays on and battery drains and requires recharge every few days if I did not move the vehice.
· Super Moderator
1995 T100 2WD & 1993 MR2
Is the switch being depressed all the way by the door. One door or all of them show the same problem. Your Matrix doesn't have a switch on the dome light like this Matrix one? Site says 2009-2010 Matrix.
Pic from Toyota Dealership parts website.
(click on image to enlarge)
SOLD 01 Avalon XL, KEPT 03 Avalon XL
One cause of this with other makes is the switch in the door handle - you might look into or ask around about that. Toyota shields its door locking mechanisms pretty well, but eventually things get gummed up and/or corroded.
Discussion Starter · #4 ·
Thanks for reply. The doom light switch as shown in your picture does work properly on all its three positions; OFF, Door, and ON. The issue is the ECU stays on thinking the door is open and drains the battery. I have checked all the doors and locking mechanisms are working fine as well. This issue started when I install aftermarket remote start on it that had a keyfeb. I have taking it back to the same garage that install it and they telling me everything has been removed and back to its original. I have checked all the wiring and nothing was cut they were tab into and at this point do not know where to go with it.
1 - 4 of 4 Posts
