And this is why I suggest doing it the way thirdcel told you. You can also do it from the front if you turn the cluster the right way, but I've had mine out so many times, it only takes me like 10 minutes now....stabbing the cable back in the trani is a true pain in the ass though but yull get it.
ok when i unscrew all 3 screws (2 on top 1 on bottom) and took out the light dimmer it barely moves? am i missing some mroe screws?After you pull out the wiring on the top, you can't miss the speedo cable. It is easier to get from under the dash. Get one of those LED headlamps and you will make things easier. Just be gentle, the plastic clip that holds it won't be too healthy after all these years.
