Toyota Pickup Axle Gear Ratios
4366 Views 1 Reply 2 Participants Last post by  fourwd1
hi i have a 1993 22re toyota pickup extended cab that i lifted and i put a front differential my 1989 22re toyota pickup regular cab pickup in it.
-i forget why i changed it i think something was stripped out on mine when i lifted it so i needed the other differential
-the problem is that when in 4-low i can creep a few feet and the truck will stop and if i give it gas and go past where it stops the rear tires will start digging into the dirt and spinning when the front ones are still creeping along slow.
- so my dad and friend think that the front axle i put in the truck has a different gear ratio then the rear axle that is in the truck
- so what do you think?
- i would really like to have an answer to this question also > are the gear ratios different in 1989 than in 1993 or are the extended cabs geared different than regular cabs
1 - 2 of 2 Posts
This was answered in your other thread with the same question.
1 - 2 of 2 Posts
