TOYOTA WARRANTY INFO
Toyota Platinum Coverage
Our highest level of extended service coverage for virtually every
component group in your vehicle. Coverage terms range from 3
years/50,000 total vehicle miles to 7 years/100,000 total vehicle miles.
Why choose Platinum
- Consider this coverage if your vehicle is less than 3 years old and has fewer than 36,000 total vehicle miles.
- We’ll provide unlimited towing reimbursement to the nearest Toyota dealership.
- You’ll be reimbursed $50 per day for a maximum of five days per occurrence.
- If you’re more than 150 miles from home, we’ll cover $100 of your meals and lodging per day for a maximum of five days over the life of the agreement.
- If you sell your vehicle, the remaining coverage may be transferable, helping to enhance your vehicle’s resale value. Transferability is limited to one time only.
and components are covered at a level of protection that's right for your
vehicle and driving needs.
Note: The Following list of covered components are provided as
examples for comparison to the Gold and Powertrain coverage's.
Platinum protection covers virtually all components on new vehicles.
If your new vehicle's component does not appear on our List of Excluded
Components, it is covered by Platinum protection.
List of Excluded Components
Accessory Drive Belts, Batteries, Body Panels, Brake Linings, Pads and Shoes, Bumpers, Carpet, Chrome, Clutch Friction Disk and Pressure Plate, Dash Cover and Pad, Door Trim, Handles and Fabric, Filters, Fluids, Glass (including Windshield), Headliner, Heating Hoses, Lines and Tubes, Hinges, Hybrid System Main Relays, Hybrid Vehicle Battery, Hybrid Vehicle Battery Module/Pack, Hoses, Interior and Exterior Trim Moldings, including but not limited to, Cup Holders, Ashtrays, Covers, and Vents, Lamps, Light Bulbs, Nuts, Bolts, Clips, Retainers and Fasteners, Paint, Rotors and Drums, Rust and Corrosion Damage, Seat Covers, Service Plug, Shiny Metals, Spark Plugs, Structural Framework and Wells, Tires, Vacuum, Weather Stripping, Wheels and Rims, Windshield Wiper Blades (Rubber Component)
Covered Components
Air Conditioning/Heating
Air Conditioning Lines & Tubes, A/C Pressure Switches, Air Temperature Control Programmer, Blower Motor, Blower Motor Resistor, Compressor, Compressor Clutch Assembly, Compressor Pulley, Condenser, Condenser Fan and Motor, Cooler Control Switch, Cooler Unit, Damper Servo, Defroster Control Cable, Evaporator, Evaporator Temperature Sensor, Expansion Valve, Heater Control Head, Heater Control Valve, Heater Core, Idler Pulley, Pressure Regulator Assembly, Receiver/Dryer, Schrader Valve, Seals and Gaskets
Automatic Transmission
Transfer Case Components (All internally lubricated components) and:
Hoses, Lines and Tubes, Seals and Gaskets, Shift Linkage and Cables, Solenoids, Torque Converter, Transfer/Transmission Case, Transmission Mounts, Vacuum Modulator
Axle Assembly
4 x 4 Actuators, Axles and Bearings, Center Support Bearing, Constant Velocity Joints and Boots, Differential Carrier Assembly, Drive Axle Housing, Drive Shaft, Front Drive Shift Lever Knob, Hubs, Locking Hubs, Seals and Gaskets, Thrust Washers, Universal Joints, Viscous Coupling
Brake
Anti-Lock Braking/Traction Control Actuator, Pump and motor, Brake Booster, Brake Hoses, Lines & Tubes, Brake Pedal Subassembly, Disc Brake Calipers, Load-Sensing Proportioning Valve, Master Cylinder, Parking Brake Cable, Parking Brake Control Handle Assembly, Parking Brake Lever Subassembly, Parking Brake Pedal Subassembly, Proportioning Valve, Rear Brake Backing Plate, Seals and Gaskets, Wheel Cylinder
Computers and Electronics
Air Bag Sensors, Antenna Cord, Anti-Lock Braking/Traction Control Computer and Sensors, Automatic Shoulder Belt Computer, Circuit Opening Relay, Compact Disk (CD) Player, Cruise Control Computer, Drivers Side & Passenger Side Air Bags, Electronic Ignition Unit, Electronically Controlled Transmission/ Transfer Case Computer and Sensors, Electronically Modulated Suspension Computer, Engine Control Computer, Front Seat Air Bag Assembly, Graphic Equalizer, Knock Sensor, Navigation System, Power Mirror ECU, Power Seat Computer, Progressive Power Steering Computer, Radio Tuner, Side Impact Air Bag, Steering Sensor, Stereo Component Amplifier, Sunroof Control Computer and Relay, Tape Player, Tilt/Telescoping, Steering Computer, Traction Control Computer, Trip Computer, Variable Induction System, Vehicle Security Computer and Sensors, Wiper Module
Cooling System
Coolant Level Sensor/Tank, Cooling Fan Relay, Cooling Fan Sensor, Engine Coolant Temperature Switch or Sensor (at radiator), Engine Cooling Fan Motor, Engine Fan, Engine Fan Clutch, Engine Fan Motor, Engine Fan Shroud, Equipment Drive Pulley, Fan Bracket Subassembly, Radiator, Radiator Fan Relay, Seals and Gaskets, Thermostat
Electrical
Alternator, Automatic-Off Headlamp Sensor, Timer and Switches, Automatic Shoulder Belt Motor and Switches, Automatic Temperature Control Unit, Back-up Light Assembly, Back-up Light Switch, Battery to Ground Cable, Battery to Starter Cable, Blower Motor, Blower Motor Resistor, Charge Warning Relay, Clutch Starter Interlock Switch, Convertible Top Motor, Cruise Control Actuator/Servo, Cruise Control Sensors and Switches, Cruise Control Vacuum Motor, Defogger Relay, Distributor, Door Control Relay, Engine Coolant Temperature Gauge and Sending Unit, Engine Coolant Temperature Receiver Gauge and Sending Unit, Engine Cooling Fan Motor, Engine Tachometer, Fog Light Assembly, Fuel Gauge and Sending Unit, Fuel Receiver Gauge and Sending Unit, Guide Rail Limit Switch, Headlight Control Relay, Headlamp Washer, Horn, Horn (for theft deterrent), Ignition Coil, Ignition Switch Lock Cylinder and Key Set, Integration Relay, Lamp Failure Indicator Sensor, License Plate Light Assembly, Lock Cylinder Set, Main Relay, Manually Operated Switches, Oil Pressure Receiver Gauge, Sending Unit Guage, and Sending Unit, Power Antenna Motor and Cable, Power Door Lock Actuator, Power Mirror Defogger, Power Mirror Motor, Power Seat Motors, Power Sliding Door Motor, Power Window Motor/Regulator, Rear Shock Absorber Control Actuator, Retractable Headlamp Motor, Shoulder Belt Drive Motor, Side Marker Light Assembly, Spark Plug Resistive Cord, Speedometer, Starter Motor, Starter Solenoid, Sunroof Cables, Sunroof Motor, Taillight Control Relay, Turn Signal Flasher, Turn Signal Light Assembly, Unlock Warning Buzzer, Windshield Washer Pump, Windshield Wiper Link Assembly, Wiper Control Relay, Wiper Motor, Wiring Harnesses
Engine
All internally lubricated components and:
Air Control Valve (ACV), Air Pump, Balance Shaft, Belt Tensioner ?
Camshaft, Crankshaft, Crankshaft Pulley, Crankcase Ventilation Valve, Cylinder Heads, Engine Block, Engine Mounts, Engine Oil Reservoir, Engine Oil Reservoir Pump, Equipment Drive Shaft, Exhaust Gas Recirculation Valve, Exhaust Manifolds, Exhaust Manifold Heat Insulator, Exhaust Pipe Gasket, Flexplate, Flywheel, Idler Pulley, Intake Manifold, Intake Air Control Valve (IACV), Mixture Control Valve, Oil Cooler, Oil Filter Bracket Subassembly, Oil Pan, Oil Pressure Switch, Oil Pump, Oil Sending Unit, Pair Valve (Reed Valve), Piston, Rotary Engine components including: Apex Seals; Bearings; Eccentric Shaft; Rotor, Seals and Gaskets, Supercharger, Supercharger Bypass Valve, Supercharger Intercooler, Supercharger Relay, Tensioners, Thermal Vacuum Valve, Thermostatic Valve, Three-way Catalyst Converter Timing Belt, Timing Belt Idler, Timing Chain, Timing Cover, Timing Gears, Turbo Intercooler, Turbo Wastegate, Turbocharger, Vacuum Switch, Vacuum Switching Valve, Vacuum Transmitting Valve, Valve Covers, Water Pump
Fuel System
Air Flow Meter, Carburetor, Charcoal Canister, Diesel Fuel Injection Pump, Electronic Fuel Injection System, Electric Fuel Pump, Fuel Filler Opening Lid Hinge Spring, Fuel Injectors, Fuel Pressure Regulator, Fuel Pump, Fuel Sensors, Fuel Sending Unit, Fuel Tank, Throttle Body
Hybrid Components
Battery Current Sensor, Battery Electronic Sensor, Battery Electronic Control Unit/Module, Battery Thermistor, Blower Assembly, Blower Cooling Fan, Blower Motor Control, Circuit Breaker Sensor, Combination Meter, Electric Power Steering ECU, Engine Control Module (ECM), HV Battery Cooling System, Hybrid Vehicle Electronic, Control Unit (ECU)/Control Module, Hybrid Vehicle Generator Assembly, Hybrid Vehicle Motor Assembly, Hybrid Vehicle Transaxle Assembly, Inverter Assembly with Converter, Meter ECU, Parking Switch, Power Source Control ECU, Shift Control Actuator, Shift Position Sensor, Skid Control ECU, Smart Entry and Start System, Steering Column, Steering Link Assembly, Stop Light Switch, Transmission Control ECU, Transmission Damper Assembly
Manual Transmission
Clutch Master Cylinder, Clutch Pedal Subassembly, Clutch Release Cylinder, Position Indicator Subassembly, Gears and Shafts, Hoses, Lines & Tubes, Master Cylinder Reservoir, Radial Ball Bearing (for Clutch Release) and/or Clutch Fork, Seals and Gaskets, Shift Lever Boot and/or Retainer, Shift Lever Knob, Shift Lever Subassembly, Shift Linkage and Cables, Transmission Mounts, Transfer/Transmission Case
Steering
Gear Box internal components and:
Bushings/Bearings, Center Link, Hoses, Lines and Tubes, Horn Contact Ring, Idler Arm, Knuckle Stopper Cover, Pitman Arm, Power Steering Pump, Power Steering Pump Pulley, Rack-and-Pinion, Seals and Gaskets, Steering Column, Steering Column Coupling, Steering Column Shaft, Steering Dampener, Steering Gear Box and Pump Housing, Tie Rod End
Suspension
(Front and Rear):
Bushings/Bearings, Control Arm Shafts, Electronic Modulated Suspension Actuator/Motor and Compressor, Front and Rear Coil Springs, Front and Rear Stabilizer Bar, Front Leading Arm, Front Spring Assembly, Front Spring Shackle, Radius Arm, Spindle, Spindle Support, Steering Knuckle, Strut Rod, Sway Bar Link, Torsion Bar Spring, Upper and Lower Ball Joints, Upper and Lower Control Arms, Upper Arm Shaft
Additional Components
Accelerator Pedal and/or Bracket Subassembly, Accelerator Pedal Rod Assembly, Back Door Lock Assembly, Convertible Roof Hook, Door Lock Cylinder, Front and Rear Door Lock Assembly, Front Seat Belt, Glove Compartment Door Lock Cylinder, Glove Compartment Door Subassembly, Hood Lock Assembly, Hood Lock Control Cable Assembly, Hood Support Assembly, Rear Seat Belt, Reclining Seat Back Adjuster, Removable Roof Lock Handle, Seat Track Assembly, Shoulder Belt Guide Rail Assembly, Sliding Roof Drive Cable, Sliding Roof Guide Rail, Tail Gate Lock Assembly, Tilt Roof Lock Handle Assembly
For me 969.00 Toyota KS beat the others
