1 - 1 of 1 Posts
Located in
Toyota : Tacoma 2WD Reg Cab I4 MT 2 wd reg cab i 4 mt toyota tacoma 2 wd i 4 manual new 2 dr truck manual gasoline 2
CLICK HERE TO VIEW THE PRICE
CLICK HERE FOR MORE PICTURES
Rick Hendrick Toyota Scion 1969 Skibo Road, Fayetteville, NC 28314 Sales: 910-868-5071 Service: 910-868-5071 Parts: 910-868-5071 EBizAutos* 2014 Toyota Tacoma 2WD Reg Cab I4 MT Toyota Tacoma 2WD I4 Manual PHOTOS PHOTOS VIDEOS VIDEOS REQUEST MORE INFO VIN: 5TFNX4CN3EX038577 Stock #: 141151 Condition: New Transmission: 5 Spd Manual Engine: 2.7L I-4 DOHC 16-VALVE Drivetrain: Rear Wheel Drive Exterior Color: Silver Sky Metallic Interior Color: Graphite PHOTO VIEWER VIEW OTHER AUCTIONS EMAIL A FRIEND MORE DETAILS Vehicle Overview RICK HENDRICK TOYOTA - WORTH THE DRIVE ON I-95 - WE ARE SMALL ENOUGH TO KNOW YOU AND BIG ENOUGH TO SERVE YOU - Call Us at 910-213-3314 Features & Specifications Standard Features** – Mechanical Engine: 2.7L I-4 DOHC 16-Valve -inc: cast iron block w/aluminum alloy head and VVT-i Transmission: 5-Speed Manual 3.307 Axle Ratio GVWR: 4,650 lbs Rear-Wheel Drive 356CCA Maintenance-Free Battery w/Run Down Protection 1325# Maximum Payload Gas-Pressurized Shock Absorbers Front Anti-Roll Bar Hydraulic Power-Assist Speed-Sensing Steering 21.1 Gal. Fuel Tank Single Stainless Steel Exhaust Double Wishbone Front Suspension w/Coil Springs Leaf Rear Suspension w/Leaf Springs Front Disc/Rear Drum Brakes w/4-Wheel ABS, Front Vented Discs and Brake Assist Brake Actuated Limited Slip Differential + Exterior Wheels: 15" x 6J+45 Style Steel Tires: P215/70R15 AS Regular Composite Box Style Steel Spare Wheel Full-Size Spare Tire Stored Underbody w/Crankdown Clearcoat Paint Black Front Bumper w/1 Tow Hook Black Rear Step Bumper Black Side Windows Trim, Black Front Windshield Trim and Black Rear Window Trim Black Door Handles Black Manual Remote Side Mirrors w/Manual Folding Fixed Rear Window Light Tinted Glass Fixed Interval Wipers Front Windshield -inc: Sun Visor Strip Fully Galvanized Steel Panels Rear Splash Guards Argent Grille Tailgate Rear Cargo Access Integrated Storage Auto Off Aero-Composite Halogen Daytime Running Headlamps LED Brakelights + Other Radio: Entune AM/FM/CD -inc: MP3/WMA playback capability, 6.1" touch-screen display, auxiliary audio jack, USB 2.0 port, iPod connectivity and control, Bluetooth hands-free phone capability, phone book access, advanced voice recognition and music streaming Radio w/Seek-Scan, Clock and Speed Compensated Volume Control 4 Speakers Fixed Antenna + Interior Front Tilt-Forward 4-way Adjustable Bench Seat -inc: adjustable headrests Cloth Front Seats w/Cloth Back Material 4-Way Driver Seat -inc: Manual Recline and Fore/Aft Movement 4-Way Passenger Seat -inc: Manual Recline and Fore/Aft Movement Manual Tilt/Telescoping Steering Column Gauges -inc: Speedometer, Odometer, Engine Coolant Temp, Tachometer and Trip Odometer Entune Selective Service Internet Access Front Cupholder Front Cigar Lighter(s) Remote Entry w/Illuminated Entry Manual Air Conditioning Glove Box Driver Foot Rest Interior Trim -inc: Metal-Look Interior Accents Full Cloth Headliner Cloth Door Trim Insert Urethane Gear Shift Knob Day-Night Rearview Mirror Passenger Visor Vanity Mirror 2 12V DC Power Outlets Regular Dome Lighting Full Carpet Floor Covering Instrument Panel Covered Bin, Interior Concealed Storage, Driver And Passenger Door Bins Manual 1st Row Windows Analog Display Air Filtration + Safety Electronic Stability Control (ESC) ABS And Driveline Traction Control Side Impact Beams Dual Stage Driver And Passenger Seat-Mounted Side Airbags Low Tire Pressure Warning Dual Stage Driver And Passenger Front Airbags Curtain 1st Row Airbags Airbag Occupancy Sensor Outboard Front Lap And Shoulder Safety Belts -inc: Height Adjusters and Pretensioners + EPA Fuel Economy & Specification Vehicle Name : Toyota Tacoma Body Style : Standard Cab Drivetrain : Rear Wheel Drive Passenger Capacity : 3 Gross Vehicle Weight Rating Cap (lbs) : 4650 Fuel Economy Est-Combined (MPG) : 23 EPA Fuel Economy Est - City (MPG) : 21 EPA Fuel Economy Est - Hwy (MPG) : 25 Gross Combined Wt Rating (lbs) : 7500 Dead Weight Hitch - Max Trailer Wt. (lbs) : 3500 Dead Weight Hitch - Max Tongue Wt. (lbs) : 350 Wt Distributing Hitch - Max Trailer Wt. (lbs) : 3500 Wt Distributing Hitch - Max Tongue Wt. (lbs) : 525 Maximum Trailering Capacity (lbs) : 3500 Engine Order Code Engine Type : Regular Unleaded I-4 Displacement : 2.7 L/164 Fuel System : Sequential MPI SAE Net Horsepower @ RPM : 159 @ 5200 SAE Net Torque @ RPM : 180 @ 3800 Trans Order Code Trans Type : 5 Trans Description Cont. : Manual w/OD Trans Description Cont. Again First Gear Ratio :)1) : 3.95 Second Gear Ratio :)1) : 2.06 Third Gear Ratio :)1) : 1.44 Fourth Gear Ratio :)1) : 1.00 Fifth Gear Ratio :)1) : 0.81 Reverse Ratio :)1) : 4.22 Trans PTO Access : No Transfer Case Power Take Off : No Cold Cranking Amps @ 0~deg~ F (Primary) : 356 Cold Cranking Amps @ 0~deg~ F (2nd) : 356 Tons/yr of CO2 Emissions @ 15K mi/year : 8.0 (Est) Engine Oil Cooler : None Suspension Type - Front : Double Wishbone Suspension Type - Rear : Leaf Axle Type - Front : Independent Axle Type - Rear : Rigid Axle Axle Ratio :)1) - Front : 3.31 Axle Ratio :)1) - Rear : 3.31 Front Tire Order Code Rear Tire Order Code Spare Tire Order Code Front Tire Size : P215/70SR15 Rear Tire Size : P215/70SR15 Spare Tire Size : Full-Size Front Wheel Size (in) : 15 X 6 Rear Wheel Size (in) : 15 X 6 Spare Wheel Size (in) : Full-Size Front Wheel Material : Styled Steel Rear Wheel Material : Styled Steel Spare Wheel Material : Steel Steering Type : Rack-Pinion Turning Diameter - Curb to Curb (ft) : 36.8 Brake ABS System : 4-Wheel Brake ABS System (Second Line) : 4-Wheel Disc - Front : Yes Front Brake Rotor Diam x Thickness (in) : 10.8 Rear Brake Rotor Diam x Thickness (in) : 10 Drum - Rear : Yes Rear Drum Diam x Width (in) : 10 Fuel Tank Capacity, Approx (gal) : 21.1 Fuel Tank Location : Midship Aux Fuel Tank Location : Midship Front Head Room (in) : 40 Front Leg Room (in) : 41.3 Front Shoulder Room (in) : 58.1 Front Hip Room (in) : 53.6 Wheelbase (in) : 109.6 Width, Max w/o mirrors (in) : 72.2 Height, Overall (in) : 65.8 Ground to Top of Load Floor (in) : 35.4 Ground Clearance, Front (in) : 8.1 Ground Clearance, Rear (in) : 8.1 Cargo Box Length @ Floor (in) : 73.5 Cargo Box Width @ Top, Rear (in) : 56.7 Cargo Box Width @ Floor (in) : 56.7 Cargo Box Width @ Wheelhousings (in) : 41.5 Cargo Box (Area) Height (in) : 18 ** These are the standard features and specifications for this vehicle. Actual features may vary. Please see the details for this vehicle above. Additional Photos About Rick Hendrick Toyota Scion We take great pride in being a member of the Hendrick Automotive Group - one of the largest automotive groups in the nation! We have been serving Fayetteville, Fort Bragg, Pope Air Force Base and the surrounding area in the Sandhills of North Carolina since 1983. With one of the largest inventories of New Toyota Cars and Trucks, New Scions and Pre-owned Vehicles in the area we can provide our customers with a variety of options not found at most other dealerships. Rick Hendrick Toyota is a full-service dealer offering everything our customers need for their automotive needs. BUYER RESOURCES Financing Information Good Credit / Bad Credit - All Applications Accepted Contact us today at 910-868-5071 for more information, or fill out our Online Credit Application to begin the pre-approval process today. Options & Features Ext / Int Color Silver Sky Metallic with Graphite Interior Luxury Features Air Conditioning Tilt Steering Wheel Tachometer Tinted Windows Safety Features Anti-Lock Brakes Traction Control System Side Air Bags Intermittent Wipers Dynamic Stability Control Audio / Video Factory System Additional Features Rear-Wheel Drive, 4-Way Passenger Seat -inc: Manual Recline and Fore/Aft Movement, Entune Selective Service Internet Access, Front Cupholder, Front Cigar Lighter(s), Remote Entry w/Illuminated Entry, Glove Box, Driver Foot Rest, Interior Trim -inc: Metal-Look Interior Accents, Full Cloth Headliner, Cloth Door Trim Insert, Urethane Gear Shift Knob, Day-Night Rearview Mirror, Passenger Visor Vanity Mirror, 2 12V DC Power Outlets, Regular Dome Lighting, Full Carpet Floor Covering, Instrument Panel Covered Bin, Analog Display, Air Filtration, Tires: P215/70R15 AS, Regular Composite Box Style, Full-Size Spare Tire Stored Underbody w/Crankdown, Clearcoat Paint, Black Front Bumper w/1 Tow Hook, Black Rear Step Bumper, Black Side Windows Trim, Black Door Handles, Fixed Rear Window, Front Windshield -inc: Sun Visor Strip, Rear Splash Guards, Argent Grille, Tailgate Rear Cargo Access, Integrated Storage, Auto Off Aero-Composite Halogen Daytime Running Headlamps, LED Brakelights, 3.307 Axle Ratio, GVWR: 4, 356CCA Maintenance-Free Battery w/Run Down Protection, 1325# Maximum Payload, Front Anti-Roll Bar, 21.1 Gal. Fuel Tank, Double Wishbone Front Suspension w/Coil Springs, Leaf Rear Suspension w/Leaf Springs, Brake Actuated Limited Slip Differential, Side Impact Beams, Low Tire Pressure Warning, Dual Stage Driver And Passenger Front Airbags, Airbag Occupancy Sensor2 12V DC Power Outlets,4-Way Passenger Seat -inc: Manual Recline and Fore/Aft Movement,Air Filtration,Analog Display,Cloth Door Trim Insert,Day-Night Rearview Mirror,Driver Foot Rest,Entune Selective Service Internet Access,Front Cigar Lighter(s),Front Cupholder,Full Carpet Floor Covering,Full Cloth Headliner,Glove Box,Instrument Panel Covered Bin Interior Concealed Storage Driver And Passenger Door Bins,Interior Trim -inc: Metal-Look Interior Accents,Passenger Visor Vanity Mirror,Regular Dome Lighting,Remote Entry w/Illuminated Entry,Urethane Gear Shift Knob,Argent Grille,Auto Off Aero-Composite Halogen Daytime Running Headlamps,Black Door Handles,Black Front Bumper w/1 Tow Hook,Black Rear Step Bumper,Black Side Windows Trim Black Front Windshield Trim and Black Rear Window Trim,Clearcoat Paint,Fixed Rear Window,Front Windshield -inc: Sun Visor Strip,Full-Size Spare Tire Stored Underbody w/Crankdown,Integrated Storage,LED Brakelights,Rear Splash Guards,Regular Composite Box Style,Tailgate Rear Cargo Access,Tires: P215/70R15 AS,Airbag Occupancy Sensor,Dual Stage Driver And Passenger Front Airbags,Low Tire Pressure Warning,Outboard Front Lap And Shoulder Safety Belts -inc: Height Adjusters and Pretensioners,Side Impact Beams Contact Jackson Ferrell for more information Phone:*** 910-868-5071 Mobile:*** 910-988-6132 Request More Info Warranty Information New Vehicle Extended Service Agreement: The purchase of a new vehicle is an investment, and like any investment, it should be protected. Hendrick Autoguard protects against unexpected repairs to almost every component on your vehicle, assures you peace of mind and protects your new investment with the most comprehensive service contract available. Pre-Owned Vehicle Extended Service Agreement: Enjoy peace of mind and protect your investment with a variety of plan options to meet your budget and driving needs. Hendrick Autoguard minimizes the uncertainty of purchasing a used vehicle by protecting against unexpected repairs to most major components. Ask for Hendrick AutoGuard. A higher level of protection. Shipping Information uShip is an auction style marketplace, where feedback rated USHIP auto transporters compete for your business. List FREE! No Obligation to Accept Bids! Click the logo to get more information on shipping this vehicle to you. Terms of Sale Overview We reserve the right to end this listing at anytime should the vehicle no longer be available for sale. The following terms of sale apply to all of our listings. Payment Terms: This vehicle may be listed on an eBay online auction. The successful eBay high bidder will submit a $1,000 non-refundable deposit within 2 business days of the close of the eBay auction to secure the vehicle. The eBay buyer agrees to pay remaining balance due (plus applicable fees and taxes) within 3 BUSINESS days of the close of the eBay auction. All financial transactions must be completed before delivery of the vehicle. Payment Methods: Cash (in person), certified check, bank transfers, or 3rd-party financing. Fees and Taxes: $549.00 Dealer Administrative Charge is not included in advertised price. All prices and offers are before tax, tag, title, license and mv rights act fee. Out of state buyers are responsible for all state, county, city taxes and fees, as well as title/registration fees in the state that the vehicle will be registered. All prices and offers include all rebates and incentives which the dealer retains unless otherwise specifically provided. Dealer not responsible for errors and omissions; all offers subject to change without notice, please confirm listings with dealer. Out of State Sales: Regardless of your state of residency or physical location, all vehicles shall be delivered at the dealership, but upon your request, the dealership may assist you in arranging to have the vehicle transported by a third party to your location of choice at your expense. Out of state customers shall be solely responsible for state and local taxes due on, and registrations for, all vehicles. Location & Transportation: All vehicles may not be physically located at this dealership but may be available for delivery through this location. Transportation charges may apply. Please contact the dealership for more specific information. All vehicles are subject to prior sale. Law & Venue: The sale or lease of any vehicle, and any other goods or services provided by the dealership (collectively, a "Transaction"), and all claims and causes of action (whether statutory in contract or tort) that may be based upon, arise out of or relate to such actual or proposed Transaction (including any claim or cause of action based upon, arising out of or related to any representation or warranty made or as an inducement to enter into a Transaction) shall be governed by and construed and enforced in accordance with the internal laws and judicial decisions of the state in which the dealership is located, without regard to conflict of law provisions thereof. Any litigation, action or proceeding arising out of or relating to a Transaction shall be instituted exclusively in any state court in the state and county in which the dealership is located. These Terms of Use are void where prohibited by law, and the right to access this website is revoked in such jurisdictions. Quick Links Warranty Info Financing Info Shipping Info Terms of Sale Rick Hendrick Toyota Scion Fayetteville NC Contact Jackson Ferrell Phone: 910-868-5071 Mobile: 910-988-6132 Contact Jackson Ferrell for more information Phone: 910-868-5071 Mobile: 910-988-6132 REQUEST MORE INFO It is the customer's sole responsibility to verify the existence and condition of any equipment listed. Neither the dealership nor eBizAutos is responsible for misprints on prices or equipment. It is the customer's sole responsibility to verify the accuracy of the prices with the dealer. Copyright © 2001-2014 eBizAutos.**All Rights Reserved. * eBay Motors Software*by eBizAutos * Counter Provided by eBizAutos.com FREE! Sellers: Add a FREE map to your listings. FREE!
IF YOU ARE INTERESTED IN THIS PRODUCT, CLICK HERE TO BID OR TO BUY IT NOW
1 - 1 of 1 Posts
About this Discussion
1 Participant
Toyota Parts
Toyota Nation Forum
Full Forum Listing
