1 - 11 of 11 Posts
Hey guys how ya'll doing...I'm new here
I have a question. I'm going to be doing a project this weekend painting brake calipers on the new tundra and i was just wonder what are the safest jack points to jack the truck up on and set onto jacks...Pictures would be GREAT! Thanks a lot! After the install this weekend, i'll definetly post up pictures on how it looks
2007 Tundra CrewMax
like the front end of your truck. have not seen a tundra with fog lights behind the grill yet.. till i seen yours :) :thumbup:
Thanks. As far as I know mine is the only one and another guy was working on doing the same thing. I did it all myself including welding up my own brackets. They are eurobeam driving lights and light up EVERYTHING.
Okay, I know that without a sway bar installed, we can jack up the backside using the rear axle areas. But with the sway bar installed, the bar is positioned real close to the axle so you it's real tight to use those areas the manual suggests. What I ended up doing was jacking up the section where the sway bar mounting plates are connected to the rear axle. Anyone did this or has a better suggestion? Oh yeah, I'm using a 3 ton lift.
· GO PATRIOTS!
2007 Tundra
Not to jack this thread (no pun intended), do you have any pics of the bracket you built? Looks great man!!!
2007 Tundra CrewMax
1 - 11 of 11 Posts
