1 - 15 of 15 Posts
Toyota Addict
2018 Camry XSE
Toyota USA Comprehensive List of TSBs for 10th Gen 2ZR 1.8L [Update 1/10/2012]
I am attempting to make a comprehensive list of TSBs from Toyota USA. First are the "Customer Interest" and then I will list the Recall and General Info TSBs.
Edited 06/16/2010 to include some TSBs which are only applicable to the 2009 Corolla.
Edited 11/25/2010 with 3 more. Sorry it has been so long. Hope I haven't missed any in this gap of time.
Edited 1/06/2011 Added one I must have missed or wasn't yet posted last time I updated.
Customer Interest
SB-0200-11...........12/16/2011 MIL ON P043E, P043F, P2402, & P2419 Due to Water Intrusion into Charcoal Canister
http://s1207.photobucket.com/albums/bb470/clintj85/T-SB-0200-11/
SB-0180-11...........11/15/2011 MIL "ON" P0717 Due to Rodent Damage
http://s1207.photobucket.com/albums/bb470/clintj85/T-SB-0180-11/
SB-0124-11...........09/06/2011 Momentary RPM Decrease Above 40 MPH... 2011 Corolla
SB-0071-11...........07/13/2011 Automatic Transmission Replacement Precautions
Service Category - Drivetrain
SB0069-11............07/05/2011 Fuel System - Extended High Altitude and or Hot Crank Time
SB0014-11............02/17/2011 AT - Torque Converter Bolt Installation Precautions
Applies to practically every Toyota From 1990-2011
SB0006-11............01/06/2011 A/T - World Standard Automatic Transmission Fluid
SB-0004-11...........01/05/2011 Charging System - Charge Lamp ON/Alternator Noisy
Essentially Replace Alternator
SB-0367-10...........12/23/2010 Seat Belt Extenders
Toyota will provide free seat belt extenders at no cost through local Toyota Dealers
SB-0310-10...........11/5/2010 Shift Lever Cover Slide Binding Feeling
Campaign.............10/12/2010 Engine Drive Belt Replacement
SB-0282-10..........10/6/2010 MT - Grinds Shifting Into 3rd Gear
Covered under Powertrain 60 Month /60000 mi warranty
SB-0281-10..........10/6/2010 Body - Trunk Lid Won't Stay Fully Open
SB-0216-10..........08/03/2010 Lighting - DRL Deactivation Procedure
Toyota uses a lot of words to tell you to disconnect battery, locate the wiring harness behind the glove box and cut blue wire in position 12 then use electrical tape to cover the end. Then reconnect the battery.
SB-0140-10R1.......06/03/2010 Steering On-Center Feel
SB0136-10........05/28/2010 Engine - Drive Belt Squealing Noises
Basically covers your serpentine belt. Apparently they crack and squeak pretty early.
Engine - 2ZR-FE 1.8L Corolla/Matrix
All Nummi (1NX VINs)
TMMC Pre VIN number ending in 319135 and for the Matrix 319129
SB0238-09R1.....05/03/2010 Audio System - Erratic Radio Faceplate Operation
Replaces radio for quite a few Toyotas. Appears as if we don't have a new unit as of yet and we just get a replacement of same dysfunctional one.
SB0108-10.........4/13/2010 Wipers/Washers - Underhood Rattling Noise
SB0099-10........04/09/2010 AT Controls - MIL ON and or DTC P0713 Set
SB0339-09R1.....03/09/2010 Interior - Lower B-Pillar Moulding Is Loose
SB0100-09R1.....03/09/2010 Remote Starting System - Cold Weather Starting Tips
RES (Remote Engine Start) was not designed to operate at temperatures below -22*F. Non-operation below this temperature should be regarded as normal.
SB0362-09R1.....12/04/2009 Cooling System - Coolant Leak/Noise From Water Pump
Introduction
Some 2009 - 2010 model year Corolla and Matrix vehicles may exhibit a small coolant leak and/or abnormal noise from the engine compartment originating at the water pump assembly.
SB0392-09.........12/02/2009 Brakes - Premature Front Brake Pad Wear
Introduction
Some 2009 - 2010 model year Corolla vehicles may exhibit premature pad wear. Use the following replacement pads to address this condition.
SB0384-09.........11/19/2009 A/C - Intermittent Odors
Introduction
Some 2009 - 2010 Corolla vehicles may exhibit an intermittent HVAC system odor. A newly designed evaporator sub-assembly has been made available to decrease the potential for HVAC odor.
Applicability
SB0213-09R1......09/24/2009 Engine Controls - MI ON/DTC P0456 Set
Introduction
Some 2010 model year Corolla and Matrix vehicles may exhibit a MIL "ON" condition with Diagnostic Trouble Code (DTC) P0456 - Evaporative Emission Control System Leak Detected (Very Small Leak) with no physical leak. The Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) logic has been modified to reduce the possibility of this condition occurring.
Applicability - 2ZR (Non XRS)
SB0087-09R1......09/22/2009 Engine - Brief Rattle/Knock On Cold Start Up
Introduction
Immediately following a cold soak startup some 2009 - 2010 model year Corolla and Matrix vehicles may exhibit a brief knock/rattle noise from the engine compartment for approximately one second.
SB0339-09.........09/18/2009 Interior - B-Pillar Trim Is Loose
Introduction
Some 2009 - 2010 Corolla and Matrix vehicles may exhibit a condition where the Lower "B" Pillar trim garnish becomes loose or detached. A new clip has been developed to address this concern.
SB0271-09.........08/11/2009 Audio System - Satellite Radio Inop Until Ign. Is Cycled
Introduction
Some customers with vehicles that are equipped with a PPO/DIO accessory XM Satellite Radio Receiver (P/N 86180-0W030 or 86180-0W031) may exhibit one or more of the following conditions:
^ XM Satellite Radio becomes non-operational or locked while in use. ^ Sound output becomes sporadic or non-existent. When either of these conditions occur cycling the ignition from "ON"-"OFF"-"ON" restores normal operation.
Improved XM Satellite Radio Receiver exchange units are available to correct this condition.
NOTE
^ This condition is NOT reception related. Switching modes will not correct the condition. ^ This condition affects XM ONLY - AM/FM reception is normal when this condition occurs. ^ If cycling the ignition key does NOT restore normal operation, this TSB does NOT apply.
SB0243-09.........07/31/2009 Steering - Clunk/Pop Noise When Turning
Some 2009 - 2010 Corolla and Matrix vehicles may exhibit a clunk pop or knocking noise when turning the steering wheel to the left or right. A new intermediate shaft has been developed to address this condition.
Applicability
SB0247-09.........07/31/2009 Body - Front Door Wind Noise Near The B-Pillar
Applicability - 2009 Corolla
Some 2009 model year TMMC built Corolla and Matrix vehicles may exhibit an excessive wind noise condition most noticeable from the driver's or passenger's side front door near the "B" pillar
SB0241-09.........07/30/2009 Interior - Water Dripping From Headliner Near A-Pillar
Caused by condensation between roof and headliner
Applicability - 2009-2010 Corolla
Procedure - Adds Felt & Silencer between roof and headliner
SB0047-09R2.......07/21/2009 Electrical - Multiple Warning Lamp ON/No Shift From PARK
Applicability - 2009 Corolla/Matrix
Introduction
Some customers may experience multiple warning lights illuminated vehicle not shifting from Park to Drive and other accessories becoming inoperative after the vehicle has cold soaked in sub freezing (below 14°F[-10°C]) ambient air temperatures. A newly designed relay has been made available to improve this condition
SB0142-08R2.......07/13/2009 Body - Windshield/Back Glass Ticking Noises
2003-2009 Corolla (and practically every other vehicle manufactured from Toyota)
Introduction
If a creak tick or rattle noise is heard at the top or bottom of the windshield or at the top of the rear glass the source of the noise may be the two stoppers bonded to the top of the windshield/rear glass or the windshield retainers bonded to the lower edge of the windshield. This bulletin provides the recommended repair procedure to eliminate these types of noises from the windshield/rear glass area.
SB0205-09..........07/06/2009 Brakes - ABS Lamp ON/DTC's C0210/C0215
Applicability - 2009 Corolla/Matrix 2WD
Introduction
Some 2009 model year Corolla and Matrix vehicles may exhibit an ABS MIL "ON" condition with either one or both of the following Diagnostic Trouble Codes (DTCs):
^ C0210 - Rear Speed Sensor RH Circuit
^ C0215 - Rear Speed Sensor LH Circuit
A newly designed speed sensor connector is available for this condition.
SB0182-09.........06/19/2009 Engine Controls - Hard Start/MIL/DTC's P0300-304/P0015
Introduction
Some 2009 model year Corolla and Matrix vehicles may exhibit one or more of the following conditions after a cold soak due to carbon accumulation in the engine combustion chambers:
^ Crank No Start
^ Extended Crank
^ MIL "ON" DTC P0300, P0301, P0302, P0303, P0304, and/or P0015 set within 60 seconds of engine run time.
The Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) logic has been modified to improve this condition.
SB0175-09.........06/11/2009 Engine Controls - MIL ON/DTC P0456 Set
Introduction
Some 2009 model year Corolla and Matrix vehicles may exhibit a MIL "ON" condition with Diagnostic Trouble Code (DTC) P0456 - Evaporative Emission Control System Leak Detected (Very Small Leak). The Engine Control Module/ECM (SAE term: Powertrain Control Module/PCM) logic has been modified to reduce the possibility of this condition occurring.
SB0288-08R1......06/10/2009 Interior - Squeaking Noises From The Front Seat
Applicability - All
Procedure - R&R Seat Track Pins
SB0104-09.........04/10/2009 Engine - Oil Filter Cap Assembly Precaution
Oil Filter cap should be torqued to 25 (+/- 5) N*m or 18(+/-3.7)ft*lbf. SST 09228-065002-02 or 09228-06501
(I use a Filter Socket I got from Matco with is part "TOY640" (64mm 14 Flute)
Recall/General Info
SB0111-10.............04/19/2010 Fuel System - Throttle Body Update
Updates part numbers for XRA Throttle Body
SCA0A...................02/04/2010 Recall - Accelerator Pedal Sticking
NHTSA10V023000....01/27/2010 Recall 10V023000: Accelerator Pedal Sticks Wide Open
NHTSA10V017000....01/21/2010 Recall 10V017000: Accelerator Pedal Sticking
SB0079-09R1..........12/23/2009 Vehicle - Long Term Storage Guidelines
SB0345-08R2..........12/22/2009 Tires - Pressure Compensation And Adjustment
SB0053-09R1..........11/05/2009 Restraints - Seat Belt Extenders
SB0301-08R1.........10/20/2009 Engine - Serial Number Locations/Identification
SSC90G.................09/01/2009 Recall - Air Bag Label Non-Compliance
NHTSA09V338000....08/26/2009 Recall 09V338000: Brake Booster Vacuum Connector Freezes
SC90H-Phase-2.......08/26/2009 Campaign - Brake Vacuum Port
SC90H-Phase-1.......08/26/2009 Recall - Brake Vacuum Port Freezing
NHTSA09V332000....08/19/2009 Recall 09V332000: Air Bag Label Non-Compliance
SB0154-09..............05/01/2009 Restraints - Proper Rear Seat Belt Orientation
CRIB173.................04/01/2009 Paint - Refinishing Information
SB0093-09..............03/18/2009 Interior - Sun Visor Removal/Installation Procedure
SB0084-09..............03/12/2009 Tire Monitor System - 'Lost Communication With ECU' Mssg
CRIB165.................03/01/2009 Body - Acid Rain Paint Damage Prevention/Repair
CRIB172.................03/01/2009 Body - Bumper Component Repair
SB0039-09..............01/15/2009 Instruments - Compass Calibration Procedure
SB0034-09..............01/15/2009 Tire Monitor System - Activation & Initialization
CRIB170.................10/01/2008 Body - Plastic Bumper Refinishing
CRIB164..................09/01/2008 Vehicle - VIN Plate/Certification Label Replacement
CRIB167..................07/01/2008 Body/Interior - Trim Removal & Installation
CRIB163..................02/01/2008 Body - Sealing Hem-Flanges & Body Seams
CRIB161..................01/01/2008 Body - Collision Damage Repair Precautions
CRIB160..................12/01/2007 Restraints - SRS Service Precautions
CRIB158..................10/01/2007 Body - Panel Adhesive Information
CRIB155..................08/01/2007 Body/Frame - Sectioning Information
CRIB156..................08/01/2007 Electrical - SRS And HV Wiring Repairs
CRIB146..................09/01/2006 Body - Paintless Dent Repair Information
The random one
2010 Corolla CE
SB-0140-10.......06/03/2010 Steering On-Center Feel
Canada:
Went to dealer for an alignment because i installed trd springs, and it turned out i got the alignment free because it was within 1 year. I asked about this correction for the steering and the service adviser said he heard a rumor that a tsb might be coming out for steering correction in canada, wich he doubted it was this similar tsb in canada. I actually printed this one and showed him and he said it might come out lil later on in canada.
09 Corolla S
Apparently there is a few new TSBs.
SB-0069-11 July 5, 2011
Extended Crank at High Altitude with High Temperatures
2009-2011
Some 2009 – 2011 model year Corolla or Matrix vehicles may exhibit a temporary extended crank condition when attempting to start the vehicle following operation in high altitude , high temperature, and high vehicle load conditions. Replace the fuel pump to address this condition.
TT-0103-11 June 2011 (Tech Tip)
Front Axle Oil Seal Leaks (2ZR-FE)
Some vehicles equipped with the U340 or U341 automatic transaxle may exhibit an automatic transaxle fluid leak from the front axle oil seals.
Happy TN user
2009 Corolla S
Wow, awesome work. If I'm not mistaken, I finally found the TSB I've been looking for. My Corolla has the dreaded "grinding" noise when turning in very cold climates. I think it's the SB0243-09. Can't wait to provide my dealership with this info and finally have it repaired RIGHT!
Sent from my DROIDX using AutoGuide.com App
1 - 15 of 15 Posts
