Did a little searching and read through the manual on the TPMS. Has anyone tried to disable the system all together? If so, were you successful? Or did disabling the system trip any CEL's? The reason I ask is because I dont see the need for it. Doing a bit of reading I see there are a couple little service tricks to disable the initialization by jumpering 2 points on the TPMS ECU. But would that disable the system? I also read into the troubleshooting portion and it says that if the system is not working to check a couple things and one of those things is the TPMS antenna and reciever. So, if that were a possible symptom for the system not working, could one potentiall disconnect the reciever/antenna and disable the system? If so, would that trip any CEL's? Or would the system just not function with no lights warning of the loss of that system?
I plan on picking up a set of aftermarket wheels and tires and I'll be damned if I am going to buy another set of sensors or swap over my stock sensors. Just to make the new wheels work with the system. I also dont want to have to deal with that warning light being on. There has to be someone, or some way, to disable the system without having any kind of rediculous lights coming on. If the aformentioned theories I posted would result in CEL's I guess I could dig more into the wiring diagrams and see for myself. I mean, if its just a matter of grounding out the signal going from the TPMS ECU to the light itself, then I may just do that to avoid having the stupid light come on when i swap out wheels.
Anyone get into it this much?
