1 - 7 of 7 Posts
Found a deal on a set of 4 alum oem wheels so I don’t have to keep flip flopping winter/summer tires on my car. Rims didn’t come with any sensors, which is the best sensors to buy (aka not a cheap one that will be dead in a year, or one that can’t be “cloned”. Likely going to buy 2 sets of sensors and replace the ones in my set now also, as I have 2 that constantly leak, so might as well fix the problem instead of having to toss 6-8lbs of air into those tires every 2-3 weeks
I think on my next winter tire change, im asking that they remove the tpms from there. its just a potencial leak in the future :p
A valve stem is a valve stem, it’s not the tpms fault that mines leaking, it’s 10 years old almost and no shortage of corrosion on them
Anyone have suggestions on a set of tpms sensors? Looking for clone-able ones? And what do I need to clone them?
Rockauto has the Denso ones. Those work with the factory ones. I have replaced three out of the four sensors with the Denso ones.
Discussion Starter #6
Do they clone? And how do you do it? I’d like to have both sets have sensors so the stupid light isn’t light up for no reason
I have a Costco membership and they charge $15 to replace the sensor. I just buy the sensor from RockAuto and take it there. They do the rest.. Here is the description of the sensor..
1 - 7 of 7 Posts
