Im having similar problems as this guy did in this thread http://www.toyotanation.com/forum/showthread.php?t=262404&highlight=transmission
i was driving normal speed about 45 when all of a sudden it felt like it went into neutral. pulled off the road and put it in park. tried to put it through all the gears and it felt like it would engage but when you went to press on the gas it would just rev.
got it home and did more inspecting the fluid is at its correct level. it is a little dark (about time for replacement). i also went through the gears and you can hear sort of a swishing noise when it is in R D 2 1. (sort of like something spinning) when you take it out of gear, either into N or P the swishing noise stops.
Is this just a replace the fluid it needed it and your good to go or somthing else?
thanks for the help
87 3sfe I4
not sure if its the A140L or E is there a way i can tell either block stamp or vin?
thanks for the help
87 3sfe I4
