I have a problem with my transmission on my 1990 sport truck with a V6. It is a 5 speed manual. Something happened and it was low on gear oil for about 600 miles, mostly highway. The whinning started very slowly and got worse and worse until I figured it out. I feel stupid for not figuring it out sooner but had no reason to believe that it was low on oil since it was recently changed. When I drained what was left yesterday it was about a pint and it was black and smelled slightly burned. Anyway, I filled it up with new gear oil and about 16 ounces of Lucas. The whine is still there but not as bad. I can shift and it goes into gears ok. The higher gears whine less. I wonder if it would be the two main bearings that took the worse hit or the gears and synchros as well????? The question is, I drive a lot for work. Several 100 miles a week. What should I do. Drive it and risk getting stranded if the tranny goes? Which I can't afford to do. Find one out of a bone yard and switch? Pull this one out and rebuild it? Another thing. Time and money are limited here. Thanks a lot for any responses.
