1 - 5 of 5 Posts
Hi, I have a problem with my transmission.
Here are the following symptoms...
1) When you push the clutch pedal down, it doesn't feel like the clutch is disengaging, so it makes shifting difficult.
2) Clutch pedal doesn't feel like it has much pressure
I thought it was the clutch slave cylinder so a new one was put on, and it was then bled.
Still have the same problem, what can it be?
Kliddybaba!
AE92 Sedan
maybe ur clutch is worn? or the flywheel needs refinishing/replacing...
G
Guest
make sure your tranny fluid is at the proper level, and clean. Try pumping the clutch when pushing it down and see if that helps. If pumping it helps then you got a bubble somewhere in the system.
1 - 5 of 5 Posts
