Alright, so I'm hoping to get some help on how to self-diagnose an issue I'm having (though maybe the best answer will be to take it in somewhere to have them test it).
My 1998 Camry (309k miles) started jumping between overdrive and 3rd gear at highway speeds a couple weeks ago. No check engine light. It was about due anyway, so I drained and refilled the transmission fluid. It had good color and did not smell bad. Problem went away for about 4 days, then suddenly came back. I managed to limp home from work taking the back roads, which included several stop signs. While at a stop sign I noticed rather sluggish acceleration and realized that the engine was not shifting down to 1st, but staying in 2nd at low speeds and idle. Manually shifting between L and 2 does nothing and the car stays in 2nd gear.
I have limited knowledge on how the transmission works, but I seem to remember something about the interaction between the shift solenoids and overdrive that leads me to wonder if I have a bad electrical connection on the 1st gear solenoid (whatever its actual name is). Or maybe I have some metal flakes in the transmission fluid gumming things up. Or maybe something is wrong with the ECU. Or maybe....???
What do you think is my best method of diagnosing the problem?
Thanks.
Thanks.
