1 - 6 of 6 Posts
My daughter was driving and both front wheels locked up. I can shift the transmission into all 5 gears and reverse. But the wheels won't turn. Engine wants to stall. Could this just be 1 hub locked up or is it most likely the transmission.
Discussion Starter · #3 ·
It’s an open diff, so one wheel can be stopped, so not a locked hub.
Well I just got the tires pulled off and it is actually the driver side caliper locked up. Had a heck of a time getting the think off. Once I got it off the rotors spin free. So I guess I'm at the point to figure out if it's just the calipers or the master cylinder.
· Administrator
マズダスピード3
If it’s a master cylinder, the brake pedal travel would go to the floor.
91 Camry DX, 94 Estima SC 4WD, 95 Previa SC, 95 Corolla DX m/t
With cars this old, the calipers tend to seize up or start sticking.
If you suspect the master cylinder, put the calipers back on and start the engine; then press the brakes and see how they feel. If its stiff, then you are making good pressure; if it slowly loses pressure over time you may have an internal master cylinder leak. Also check the brake fluid level, and visually look around the master cylinder for brake fluid leaks. If all is good, the caliper is most likely the culprit. I'd check the condition of the brakes at all 4 wheels before coming to any conclusions, it could be time to replace the pads and rotors and/or rear brake components like brake shoes and wheel cylinders.
Not the same car, but a friend of mine has an early 2000s Neon where the brake material on the rear shoes broke off of the shoe and jammed against the drums, completely locking his rear wheels. And I have a 94 Toyota Van with pretty low miles, the front left caliper seized on the second piston and drug the brake pad; could really smell the cooked pads and probably warped the rotor. It happens, but brakes are cheap and easy to do.
1 - 6 of 6 Posts
