1 - 20 of 29 Posts
Does anyone know if the TRD center caps for the 19" TRD wheels will fit into the 19" XSE wheels? Might be posure-ish, but I think it might look good if they do. I know the center caps are sold separately.
Yes they do, I know a few people that have swapped them.
Just found these pics I had saved. The first pic is from a guy in one of the FB groups, those are XSE 19s powdercoated black. I can't remember where I found the second pic, might've been the same group.
296875
296876
Discussion Starter · #7 ·
Perfect...thank you!
Discussion Starter · #15 ·
Just curious, why plastic caps instead of just buying black lug nuts? I did a quick search and it seems like the caps aren't much cheaper.
I cant speak for him. Although as someone who has had black and other colored lug nuts in the past, they are so hard to keep that same color if you take your wheels off enough. The caps can be removed when you want to take them off. But I have never used caps personally, just had lugs that would get messed up.
· 16' Camry SE & 18' Camry XSE
2020 XSE AWD & 2023 XSE HV Camry
Exactly reason above. Coated lug nuts get stripped and look bad. Plastic caps are easily removable and you retain oem lugnuts. Just my take on this... I think caps were 5 bucks.
Sent from my SM-N960U using Tapatalk
1 - 20 of 29 Posts
