TRD filters V6
1153 Views 10 Replies 9 Participants Last post by  onefiend
Are there any TRD filter out there for 07 V6? this is for oil and air.
I know KN got the one for air but I wanted to keep it TRD.
Thanks
1 - 11 of 11 Posts
Nothing's listed under 2007, but as far as I have heard, and somebody will correct me if I'm wrong, the filters are the same for the 2006, so use the link and setup the search for an 06 Camry and you'll see the air and two oil filters listed, one from Japan, but both TRD.
http://www.trdsource.com/toyota.asp
nnot for v6
it is the same as Avalon
Trd does make a air filter for it. You will have to call them or email them for the part number as I do not remember it. It lists for around $55. They also make a oil filter too.
Isnt the oil filter for the v6 model a reusable one? I know u have to take it apart or something and clean it. Would that be the same for aftermarket filters like TRD or KN?
Not re-usable. You replace the element.
If you know your part # for the filter you have on it now...
TRD has a replacement for it. Larger and more expen$ive !
The one I use on my Tac06 is $16.00. What's your filter # ??
OWAF
Andy
im think you mean AIR filter. i dont think there are reuseable oil filters. i could be wrong though
EDIT - NVM found out there is such things as reuseable oil filters
Yes...the oil filter for the v6 is a replaceble element.
According to toyotapartspeople.com: P/N = PTR14-00000-04
http://www.toyotapartspeople.com/SearchProduct.asp?Model=Camry&catid=3374291817232706&year=07&productdesc=TRD+Oil+Filters
You might need to call them first to confirm.
$55, that's too pricey. The K&N filter is like $34.
1 - 11 of 11 Posts
