TRD Springs + tire/rim combo = rubbing?
3626 Views 17 Replies 6 Participants Last post by  Kidd07
I recently purchased (as did everyone apparently) new GS430 rims for my 07 SE. However, recently I got a great deal on Eagle F1 tires size 245/40ZR18's that I couldn't pass on. I know that a few of you have run this size tire on your Camrys but have any of you with this combination also lowered yours using the TRD springs? If so, any rubbing? I have the springs but not sure that I want to risk ruining the tires if it will rub. Any assistance would be appreciated.
1 - 18 of 18 Posts
i dont think you'll rub. TRD doesnt give you that big of a drop. im running on 225/45/18 and im super clear. but dont take my word for it!
Thanks for your input. I hope you are right.
i ran that size with my 18s... you should be fine... watch the inside rear strut tho
Did you lower yours when your ran that size? I paid $450 for the tires.
For $450 drop it.:)
For $450 drop it.:)
That's what I'm thinking!:thumbup::smokin:
Remember, you can go up to 45 profile tires if you want more ride comfort.
True, but since I have the tires already, I'll see what the ride is like with the 40 series. Thank you for the advice.
Actually, both Flopshot and Rocketace have GS rims 18x8 +45 offset with 225-50-18 on them. Flopshot is lowered with TRD springs in the front and SE spring in the back. Rocketace will lower his car very soon.
I had a set of 245-40-18 before and had no problem. You'll be fine. Enjoy it.
Thanks for the heads up. Hopefully Rocketace will clear with the 50 profiles in the rear with the TRD drop.
That's a thought. Since most likely it would rub in the rear, maybe I should just install the TRD springs in the front and leave the SE springs in the rear.
Here is another option, install TRD springs front and rear. Then install the Urethane Spring Cushion that I just installed on mine. It will fix your sagging problem due to the weight of the battery. Just another thought for you.
Where did you get the Urethane Spring Cushion? Cost?
Apparently you missed this thread
http://www.toyotanation.com/forum/t232366-2.html
I got it for $140 pickup. ($150 shipped)
The price is high but he is the only one that got them for now from Korea.
I'm sure we can find a cheaper price...it's just a matter of time but I didn't want to wait.
Sweet! Thanks for the link and advice.
1 - 18 of 18 Posts
