I have a 2003 S that is kinda my "extra" car and the rear window tint was so old and decayed I could not even see through it. I was able to get it all stripped off with ammonia water and black plastic bags stuck on, using the suns heat to soak the film to soften it up and scraped off with a plastic scraper. Finished up with a razor blade on the stubborn areas. Did it without ruining the defogger lines.
After driving around sunny Arizona with no tint I decided I wanted it tinted, but thought it would cost 60 - 80 bucks to get it done at a shop. I ordered a $15 pre-cut tint film from Nexen. Watched videos and gave it a shot. You put the tint on the outside of the window temporarily and trim it and shrink it with a heat gun to get it to lay down on the curves.
It was harder than it looks. The heat shrinking did not go so well, I had some small creases and may have over heated it a bit on some edges. After deciding it was as good as I can get it, I peeled off the clear backing and sprayed it good with soapy water. Was able to get it into the car and in place. Lots of small bubbles were not able to be squeegeed out but many went away with a few days sitting out in the sun.
Its not great, but its good enough for my beater car. I definitely wont try it on my newer cars. I have new respect for those that are good at tinting.
