Check the Ground on your coil. The bracket which the coil is held together with (The Strap Attaching the Ignitor to the Coil) Needs to be grounded. Make sure its clean from rust or corrosion and give it another try.
My truck started doing that once and I found it to be a bad ground. there was no pattern to the madness, just skipping and backfiring at odd times.
