  • Hey Guest, Toyota Nation is testing a beta feature for signatures. By clicking this link, you'll be able to add a visual list of things you own to display to other members. This test is still in the early stages and very limited, but it will allow you to make your sig more dynamic and useful. Shoot us a PM to provide your feedback.
1 - 6 of 6 Posts
I would go with billstein 5100's all around. Those self leveling kits guys are putting on top of their springs are causing some major damage when going wheeling. They find that things are snapping in two. Go w/the 5100's............you will be glad you did!
Good luck!
Get out your measuring tape and measure. I did this on a 0 mile truck at the dealership and it measured 35" front and 37.5" rear but after you drive and depending on how much weight and how often your haul your rear suspension will definately settle and in some cases sag. also because of the spring rate being as soft as it is in the rear you will notice small difference in ride height based on quantity of fuel and # of passengers. Trucks just dont ride at the same height all the time. If you want to keep it closer throw some timbrens in the back. Otherwise I would say that 1.5" is all you really need to level it once your rear susp is settled. Measure yours and that will tell you. ( i measured from the ground through the center of the wheel's center cap to the bottom edge of the fender. )
Native Oregonian
07 Tacoma DC LB TRD
I have 3" front and .25" in the back, Tough Country. Level to me, if anything its a little high in the front, but I like it. I may just stick a bigger AAL in the back.
Don't know about any 'major damage' when going wheeling though. Only problems I have is rub.
1 - 6 of 6 Posts
