1 - 5 of 5 Posts
Hi there! Camry 2005 2.4 LE. Trunk does not open using wireless key. I thought there is a problem with actuator on the trunk. I gave him 12 V DC, it works. Now I can not find trunk release fuse in the fuse box. If anybody knows where it locates, please, help me.
Cruisin' along
2019 Camry LE
first, try your other key fob. maybe the truck release button on your current one is worn out.
next, the truck release fuse may actually be tied in with another fuse, like the dome light, or horn, power seat, or power plug(cigarette lighter) socket. check those out as well. not all electrical devices will have its own fuse, so many times low voltage, amperage devices are tied into one another.
Discussion Starter · #3 ·
Thank you for suggestions. But, I have checked every single fuse in the fuse box. All fuses are fine. I wonder if there special fuse separately for trunk?
Discussion Starter · #5 ·
Is this solved yet? Wondering what you did to fix it.
Sad...:disappoin I opened trims and found installed Chinese:bullshitz remote controller inside the car, instead of original. :facepalm: Seems it had a problem and they just put new one. That's why my trunk release button doesn't work. So, now I think about installing another remote wireless controller with full of function.
1 - 5 of 5 Posts
