Hi all,
I'm working on my daughters 1997 Toyota Camry 4-cyl. It had been leaking something slowly for a while and I went to drive it the other day and her power steering was not working well and making all kinds of sounds. She was low on fluid so I filled it up and the problems went away. I assumed the leak was her power steering fluid and expected the leaking to get really bad after I filled it up, but it didn't... it's still very slow.
So I let it run for a bit this morning until I saw the drip, turned it off and let it cool off and jacked it up. At first glance, it appeared obvious that it was an oil pan leak. The oil pan was dry everywhere except for the rear-passenger side corner. It was very wet to the touch right there.
It wasn't until I took that picture and looked at it that I saw the discoloration above the oil pan as well. Sure enough, it was oil... not a lot, but enough that it seems its just slowly coming down and collecting at that corner of the oil pan.
So I started looking up a little higher. That's when I noticed that there was oil all over the bottom of the exhaust headers and along the bottom of some wire conduits as well.
Note that where the oil is dripping from the oil pan is on the far drivers side of the car, but the cable conduits that have oil on them are more towards the center of the car, right in the area between the engine and the transmission.
I also noticed that the block is saturated with oil right below where the exhaust manifolds attach to the block:
So I'm assuming that for oil to collect under the exhaust manifolds, the leak must be coming from above them. I checked all over the valve covers from the top and can't find oil to save my life... nothing by dry/greasy metal. I can't find where the oil that is collecting there could possibly be coming from, and I really can't understand how oil is getting all the way over on that cable conduit but nowhere else around it. Everything else appears to be dry.
Has anybody seen something like this before? Any ideas on where this leak could be?
