1 - 2 of 2 Posts
98 4wd T100
Not that I have or want to spend a lot of money but I do need to tune up my truck....
Brief History:
The Truck has 150k miles...At 80k I replaced the timing belt, plugs (no wires) changed transmission fluid. I also replaced one of the O2 sensors because it failed..that's it (original clutch and original rear brakes)
My plan is to replace plugs and wires with OEM parts
Will have timing belt replaced (at shop)
Change oil, air and gas filter
What do you advice??? thx in advance.
yz250f,
you should also pull the coils and inspect the rubber boot that goes over the spark plugs , you should have 3 coils to 3 plugs then the coil also has a wire to go to the other side of your engine. One rubber boot on my 95 4x4 and it made it run like a toilet.
1 - 2 of 2 Posts
