1 - 4 of 4 Posts
I was wondering what the stock settin is for a stock waste gate for a ct26.. im planing on running about 8psi... if im not mistaken isnt the stock setting 14psi
boost controlers only raise the boost right? you cant go lower then what the spring in the waste gate is set at.. how do i lower that?
Lex Zues!
95 Camry
Stock is 6-8 depending on a few things but.. 6-8.
You can cut the wastegate rod in half and put a threaded coupler between the 2 rods and you can twist it in and out to lower and raise the preloaded tnesion on the wastegate
1 - 4 of 4 Posts
