1 - 4 of 4 Posts
Whats up guys is there any way that you can turn a new turbo around without messing up the seals. By turning around I mean to change the position of the outlet port so that it is at the bottom instead of the top??????? The problem that I have is my radiator is in the way of my outlet port of my t3 turbo..... Need to reposition the outlet tube so it faces the bottom of the car. You understand?????:disappoin :disappoin :disappoin
Alltrack Wannabe
Yes.
Remove the clip that holds the compressor housing on, remove the housing, remove the lock [roll] pin [if it has one], reinstall the housing at the desired angle. You can rotate it some if need be.
The only hard part is you are going to have to make the wg actuator attach to the housing in a different way. A bracket or such...
1 - 4 of 4 Posts
