I'm not arguing just stating the facts, notice that the last photo was taken at an angle, if it was straight on I guarantee you'd see the turbine straight on and the wastegate port would be cut off, not one of those wastegates actually points straight out, pipe is round..not oval, and not too many standard style dump-pipes come anything close to giving optimum flow to the wastegate port over the turbine, for packaging or routing reasons. Take a look at the top photo, the actual wastegate port is only ~50% the size of the flapper door, which is typical, you can't judge the size of the wastegate by the size of the flapper, I guarantee not one of those ports is close to 35mm. The largest I've seen was a custom one off designed by IHI and it was 25mm, unfortunately this didn't leave enough material around the seat for a decent seal. I'm sure someone has done 35mm internal custom or on a big truck unit but I doubt a car sized unit would work very well without a special turbine housing. Their is a reason why 35mm wastegates are an expensive external option. My current setup has an 8 psi actuator, and actually runs up to 12 psi due to spike thanks to my latest free flowing exhaust system. I designed the dump pipe for decent flow, but the 12mm port just doesn't cut it. If an engine generates enough exhaust gases to make 8 psi at 3000 rpm and fully open the wastegate, how much additional gas is trying to be pushed through that port at 7000 rpm?
Neil
