1 - 11 of 11 Posts
· Danno
1989 corolla GT-S
i dont think you will find a kit for the ae92... like flash said your better off making your own setup 1. because it will most likely be cheaper & 2 you can build it up for your needs
Discussion Starter · #7 ·
Thanks So much! ive been looking for another DIY project on that car ;) i have a moderate ammount of welding experiance but i could do with some talking thru it. does anyone have any previous knowledge of what metals to use or stay away from, pipe lenths, widths or directions or configurations that best fit a turbo it would be wicked to know before i start cutting! and my internals should be ok with just a stage one? right? thanks!
· Danno
1989 corolla GT-S
· The Return of the Red Coupe
2010 RAV4 V6
In other words.. do up a bigport.. the smallport has a bigger chance of getting blown.
I'm wondering the same myself.. will that manifold work with FWD setups? As it says for 85-87 Corolla GTS. I'm guessing if its ONLY the manifold it will work if the outlet is setup to point down. But if its setup to point towards the left, it might not work on FWD. :(
1 - 11 of 11 Posts
