G
Guest
·Hello,
I've spent the better part of today reading post across the internet trying
to match my symtoms with others, but to no avail...
Last night while driving I came to a stop put on my left turn signal, it
made one one audible click and froze on. I contined to make the turn and
the lever returned to its normal position, but the dash indicator stayed
lit. I pulled over for a second and got out to look at the lights and both
the front and rear drivers side turn signals lights were lit. I did a u-turn
heading back to my street, hit the right turn signal and it appeared to be
working properly from within the cab, but the left continued to stay lit. I
returned home shut off the truck and called it a night.
This morning I went out to take a better look at the issue. I started up
the truck, hit the left signal and it started flashing, however, now I'm
getting flashing lights all over the place.
When I hit the left (drivers side) turn signal, these lights flash:
- Left front panel
- Right front fender
- Right rear
- License plate
- Clock
- Radio
- Shifter
- Right front panel
- Right rear
When I hit the right (passenger side) turn signal, these lights flash:
- Right rear
When I turn on the hazards everything inside and out listed above is
flashing.
I called a local parts store and they suggested the possibility of water
somewhere. So I pulled off all light housings except the front panel lights
because I can't figure out how. I didn't find any water.
The truck is a 2000 Tacoma, V6, extended cab, all options.
Thanks for any help you might be able to provide,
Todd
- Left front panel
- Right rear
- License plate
- Clock
- Radio
- Shifter
- Right front panel
- Right rear
- Right rear
flashing.
Todd
