Two 5SFE EFI questions
353 Views 7 Replies 4 Participants Last post by  new echo owner
1/ Does this engine have sequential or batch injection?
2/ Does the fuel rail have a return line back to the tank, or is it one way only?
Thinking of experimenting with slightly heated fuel for maybe better economy and emissions. Not easy if there is a return line.
1 - 8 of 8 Posts
· Administrator
What year? Gen3’s have a return line. Gen4’s don’t.
  • Helpful
Reactions: sdspeed
· Administrator
1999 Australian build.
Thats a Gen4, so most likely it doesn’t have a return line (not sure of it, being an Aussie-built). Easy enough to check. Pull the rear seat out, remove the fuel pump access panel and see if there are one or two lines on top of the pump.
  • Helpful
Reactions: sdspeed
· just a nobody
Echo
Can you verify by looking at the fuel rail? If there is a return, there would be an extra line under the fuel pressure regulator, right?
· Administrator
Maybe. I’m not familiar with how the 5S-FE fuel lines were run, but on mine with the 3VZ-FE V6, the line first ran thru a pressure reg - front bank - looped over to the rear bank - then out the drivers side and back.
· just a nobody
Echo
Silly me! Come to think of it, when Toyota went to the returnless fuel system, they moved the fuel pressure regulator inside the fuel tank; in other words, if you don't see a fuel pressure regulator on the fuel rail, there wouldn't be a fuel return line, just a plate where the regulator used to be!
Picture in this thread shows a 2000 Camry fuel rail with the plate, step 14:
DIY Fuel rail & injectors removal - 4cyl i4 5s-fe...
1 - 8 of 8 Posts
