SWMBO seatbelt latch has been loosly flopping about on its retaining bolt.... As if the hole was too big on the bolt 😕
After stripping out the plastic cover I discovered the spring/welch washer (presumably to allow wobbly movement but not 'rattly') has fretted away and snapped.... I tried to loosen the 14mm bolt but.. even with a tube on my ratchet.. couldn't break it away
Plan B formed as using twopack adhesive to flow into the void and 'gummie up' the hole/make movement stiffer
The slight shine on the washer base is it, after glooping on with a piece of plastic.
Working just fine now(rattle-less).... see how it goes!
2sav
