I don’t have anything coming off the top of my struts thoughThough the XSE and SE already have a strut bar. Adding another one won't do much. Actually I think all grades have it.
That’s just a part of the cowl. Not a brace
So, my car doesn’t have one then? I should make some time to go out to the car and check...That’s just a part of the cowl. Not a brace
It's rigid steel and it bolts to both strut towers. It's a strut brace.That’s just a part of the cowl. Not a brace
its a strut brace.That’s just a part of the cowl. Not a brace
It’s a stamped piece of steel. If you think it’s going to provide any type of bracing or rigidity you’re mistaken. However, I got the UR brace more for looks than anything. The car would need to be pushed rather hard in a track setting to notice any type of differenceits a strut brace.
Meh...good and tight works in this instance. It’s not like we’re torquing down a head that requires a certain sequence and spec. For those that are curious, the spec is 37 ftlbsThese work great. But, you need a pulse to notice the difference. Most zombies wouldn't notice. Factory bracing is a joke.
The only issue I have is that those nuts should be torqued to spec. So, get a torque wrench, loosen them, and torque them correctly.
Well, science says metal flexes no matter the load. So a more rigid material profile of thicker HSS vs formed plate will flex less (assuming similar overall width) plus lastly the direct vs offset crossover would also make more rigidity as strut load would transfer more directly.Without any science, there is no way you can say an aftermarket brace is better than the Factory brace.
All assumptions without proof.Well, science says metal flexes no matter the load. So a more rigid material profile of thicker HSS vs formed plate will flex less (assuming similar overall width) plus lastly the direct vs offset crossover would also make more rigidity as strut load would transfer more directly.
Science can show it is better. It is how noticable it would be that cannot be assumed.
