Its physics?All assumptions without proof.
It appears you’re correct, #10 in the diagram. It’s a stamped piece of steel that they indeed call an upper suspension cross member”its a strut brace.
I agree with your point, but technically the aftermarket bar is being added to the factory brace, not replacing it. So it doesn't need to be better to be worthwhile, it just needs to offer a measurable (and ideally a noticeable) improvement over just the stock brace. Even then, "worthwhile" is obviously subjective.Without any science, there is no way you can say an aftermarket brace is better than the Factory brace.
Upgrading to a thicker rear sway bar is often a high-value mod that will immediately and noticeably improve how the car drives, especially in a lumpy family sedan.A strut bar by itself my not have any noticeable handling differences but when combined with other chassis bracing like a rear strut bar, lower bar, fender bar, etc. Then there is a possibility for a different feel. I know when I installed all of mine, it definitely felt different but since I don't track or autocross my (2008) Camry I won't feel the true difference.
Which it does. Car chassis themselve have flex in them just as a result of crash protection. Heck, half of the TRD stuff is chassis stiffeners. Basic physics. "For every action, equal and opposite" and all that. On a strut suspension, the entirety of the suspension compression as result transfers up to the strut mount and causes a torsional load in the chassis cause of all the wonderful heavy mass of engine, etc.I simply posted this to show how the UR bar looks under the hood. There are many other aftermarket options that look like junk in my opinion, and some are three piece designs. I chose the UR due to it being one piece and looking like a quality product. Didn’t expect a bunch of grown men to argue about it not being necessary or a waste of money. I like how it looks under the hood of my car wether it helps or not. Which I’m sure it does add some sort of rigidity to the chassis, as many manufacturers (including Toyota) use a similar design on their cars right out of the factory
Yes, only comment if you agree..... We have feelwings to protect.Assumptions go both ways, just like all assumptions opinions... claiming they do nothing or don't work, especially from those that have never used them.
I braced plenty of cars and they were all noticeable. That is proof enough for my driving style and commute.
There are those that do and those that don't. Those that don't shouldn't even comment on the threads started by those that do.
More like... Somebody does something nice to their car, and come in pointlessly bringing own false assumptions and sarcastic/degrading comments that had no relevance to the discussion. Making them only to give your own sense of superiority.Yes, only comment if you agree..... We have feelwings to protect.
TRD wheels be not a bad option either. Decently priced through toyota and a good weight. Get dealer installed? Even get a good warranty on em. Lighter than stock.TRD parts already mentioned. Obviously, TRD thinks that some parts could use an upgrade:
TRD under braces on my V6 XSE
I purchased directly from Toyota the beefier under braces from the TRD version for my XSE V6. If you read any of the reviews of the TRD they usually compare that version to the XSE and its noted that the TRD version is much stiffer. Yes, the TRD has different springs and struts but I'm not...www.toyotanation.com
Just added ultra racing front strut tower brace to my 2022 Camry SE Nightshade - simple install and major difference in performance - Great quality and welds and perfect fit!For those of you curious, the ultra racing front strut tower brace for the 8th Gen Camry looks and fits great. Super well built one piece brace.
Adding a strut bar to your SE/XSE/TRD won't get you any major improvements with handling.Just added ultra racing front strut tower brace to my 2022 Camry SE Nightshade - simple install and major difference in performance - Great quality and welds and perfect fit!
The proof is having it on your car and knowing the difference before and after. I feel my car drifts less on corners. All driving experience is different I agree.All assumptions without proof.
