1 - 8 of 8 Posts
06 Corolla
2009 Corolla. The blower fan works as it should when you initially start the car, then after a few minutes, it stops working completely. Works again if you turn the car off and back on again.
I don't know what can go wrong here other than the motor or the resistor Network. But the motor seems to be functioning, and normally when the resistor Network fails. It works on high but not the other speeds. I'm traveling and don't have any tools so I can't take a look for myself just yet.
Likely the blower resistor is bad. I've never had one go out on any of my Toyotas, but it can happen.
The part is around $50, depending on where you get it.
Its accessible from behind the glove box.
Here is a (not very good) video on how to replace one on a Corolla:
At about 54 seconds into it shows what the blower resister looks like.
06 Corolla
To be clear, when it works it works on all speeds, and then it stops working on all speeds.
06 Corolla
Discussion Starter #6
Could it still be the AC relay if the issue is the same whether the AC is on or not?
06 Corolla
Discussion Starter #7
Definitely not the resistor. I disconnected the resistor and the issue was the same when on high speed. I ordered a blower motor.
06 Corolla
Discussion Starter #8
Replaced the motor, so far everything is working. The resistor had some rust on it but is still working correctly.
1 - 8 of 8 Posts
