1 - 13 of 13 Posts
2000 Corolla, I don't use this car every day. When I start the car cold, with temp around 40, the idle surges for the first 2-3 minutes and then smooths out. It idles fine after that, and has no other problems and no CEL. No strange exhaust odor. Seems minor, but don't want to let it develope into something worse. Any ideas? Thanks.
· 2005ToyotaCorollaS
05 Toyota Corolla S
I think that is the PCM putting priority on emissions over smooth running engine.... I heard that somewhere for the 9th gen'er dunno if that is the case for the 2000..... if it is this I think that is the way they work...
D
G
i'm confused, is your idle up and down spuratically (can I spell?) or is it constantly higher rpms for 2-3 minutes then the idle evens out? If it is constant then dont worry about it, however if it is spuratically then daniel2002 got some info for you
G
JohnO356 said:
As Daniel said, the idle speed rises and lowers (surges). Only lasts for a minute or two when it's first started cold. The surge isnt much- maybe 100 RPM's.
100 rpms i wouldnt worry about. I thought you were talking from 1000 to 2500 and then back to 750 to 2300 and so on.
my 03 have this particular problem and a lot of other 03+ as well.
my problem started just last year around october. start up the car cold to warm up - it will stay up around 2300 rpm or so and all of a sudden, the rpm would be jumping up n down.
it's similar to when you are revving your engine - like that. no, it's not normal.
does it hurt your car in any way, shape or form. i dont know, probably not.
did lots of research and asked around a lot, most people say it's to do with the IAC valve.
if you wish, you can try cleaning your MAF sensor to see if it helps. some people tried cleaning the coolant sensor.
for me, i chose to just leave it and live with it. i was gonna take it in to get it fixed but my warranty just ran out so i'm out of luck.
goodluck.
1 - 13 of 13 Posts
