1 - 16 of 16 Posts
TN の がしょう
2015 Camry XSE V6
Well, I finally gone and got one. Sounds okay, a bit too loud for my taste, but I like it overall.
DNA Splice told me about the extra sensor port, but since the Gen 5.5 doesn't have one for that spot, I had no problem plugging it. Thanks DNA! :thumbsup:
I might change the air filter to some universal HKS filters.
TN の がしょう
2015 Camry XSE V6
Well, it's noticeably louder over the engine, but it's fine when it's at idle or cruising. It's only loud when accelerating past 3000rpm.
DNA sold his to me for $160 which included the heat shield.
As in for gain, probably not much, I'm guessing only around 1 hp more, since I've tried my best to have it away from the block as far as possible. The sensors was a bit problem for me to install because it was attached to the OEM air box, but I had no problems taking that out and putting it on the intake. The major problem I had was finding something to plug the extra sensor port, but I didn't have a problem when I was looking through some old computer parts and found a plug that had the exact fit over the hole. Problem solved. :D
I might install my TRD air filter in my dad's car later on since I won't be using it for a while. For now, I like it, but I'm more paranoid now when it's raining since it's an open air filter so I have to be careful not to drive in puddles like I used to, so I might end up buying a splash guard for the engine bay soon.
TN Pussy Man
Camry
water is not something you have to worry about until you've got a cai
and regardless, it takes a massive amount of water to hydrolock and engine. chances are that if it does suck up some water, it'll just stumble. or do nothing when the throttle is open- kind of like using seafoam
TN の がしょう
2015 Camry XSE V6
Discussion Starter · #9 ·
:D I'll see. I'm currently busy building a airbox for it.
TN の がしょう
2015 Camry XSE V6
Discussion Starter · #15 ·
1 - 16 of 16 Posts
