1 - 9 of 9 Posts
3s-gte in a Camry?!?
'89 Camry Alltrac
Hey guys, I thought you might be interested in something I recently did on my Alltrac... upgraded windshield wiper squirters! For a couple years (yes, really) my wiper squirters weren't putting out any fluid... I saw that the 4Runner guys on www.toyota-4runner.org recently found that 2011-2017 Honda Odyssey windshield squirters are a direct fit in the holes in the hood - and lo-and-behold, they match the Camry too. I think the OEM squirters between the Camry and 4Runner are even the same (two holes, crappy spray pattern).
So anyway, here's the info:
Honda PN 76810-TK8-A01
They stick up a bit higher than the stock ones, but have GREAT spray pattern and are fully adjustable. They are also OEM quality, which is a good thing... Installed finally just in time for the "winter" to arrive here in Southern California (it was 90*F and sunny on Nov 16 when I installed them) and repaired the cracked Y in the hose that was causing problems too.
Hope that helps somebody.
-Charlie
This is surprisingly awesome! Mine squirt just fine, except there is no pattern, it just squirts a jet of fluid on the windshield which promptly runs right off unless I quickly use the wipers (wipers don't work in conjunction with the spray, not sure if this is true for all Camry's or because I have base model).
Thanks for sharing this, easy upgrade to get a functional spray of fluid!
Super Moderator
Added to the DIY sticky.
1991 Camry
Charlie...thank you for the mod...I had to order a pair as I really dislike the stock ones.
'89 Camry Alltrac
I have been using them each morning just for the pleasure of spraying the windshield! :LOL:
-Charlie
1991 Camry
LOL...I hate the crappy old school stock spray pattern and the DX version wiper delay set up..so lame.
1990 Toyota Camry LE
Man, finally an upgrade over my broken oems, and the cheap autozone ones lol! Thanks for sharing this!
1991 Camry
...installed the set today and it’s a excellent upgrade...luv the wide spray pattern!
1 - 9 of 9 Posts
