For those of you who were hesitant to splice into your ECU wiring to add products such as the URD MAF calibrator, URD has pre-wired harnesses available for many applications.
http://www.xr-underground.com/forum/showthread.php?t=9309
From Gadget
URD is now offering ECU jumper harnesses. These harnesses plug in between the stock ECU and its wire harness. When installing an aftermarket Performance Calibration Unit, you can use this harness to make your splice connections. This eliminates the need to splice into your stock harness. Customers have asked for a way to install the different Performance Calibration Units in their vehicles and be able to remove them without leaving a trace. This is useful for warranty work or if you decide to sell the vehicle.
These harnesses are of the highest quality and use the very same OEM connectors that are installed on your stock ECU harness.
When ordered with one of the Performance Calibration Units URD offers, including the MAP-ECU2, we can prewire the unit into the jumper harness for you. When you received it, you can just Plug-N-Play.
From Gadget
